question about car not starting
Old Jul 24, 2009 | 12:53 AM
payam972's Avatar
payam972 is infamous around these parts
Cool question about car not starting
hey all, i have a 2001 996
the problem is, when i pump gas and turn the car Off... when i go to start the car back up, it takes about 20 seconds of continuous starting for it to start.
i tried leaving the car on...and right when i put the nozzle in the tank, the idle starts to get a little more rough, and will only resume to normal when i stop pumping.
the car drives perfect...this is the only time it acts up. CEL is on also, but came up as a catalytic converter gone bad.
is that the problem? or is it maf? any ideas?
Old Jul 24, 2009 | 10:49 AM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
How low are you letting your fuel tank get? It could be a fuel pump or pick-up issue. What is the outside temp when this happens? Vapor lock?
Of course, the CEL could be telling you what the actual problem is. It sounds like you are due to visit the dealer...
Old Jul 24, 2009 | 04:07 PM
payam972's Avatar
sometimes it gets to the gas light, but i have pumped when it has been at half tank also...same thing happens. outside temperature is always 80s-100
Old Jul 24, 2009 | 07:11 PM
slvr99M3's Avatar
slvr99M3 is infamous around these parts
Gas Problem
Sometimes the tank vent valve in the rear(engine bay) of the car in sticks open causing all of the evap fumes to get sucked in the intake when you start the car, especially at time of fill up.The valve is located right above the alternator on your car..Its pretty cheap to replace , but if you do want to test it you need a vacume pump w/ a gauge and a porsche tester to release the valve and see if it works still.If you loose all of the vacume created then you need the valve replaced.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Sep 1, 2015 03:16 PM
gulf gt
Aug 27, 2015 10:27 AM
DSCOFF
Aug 23, 2015 01:22 PM
