Question for C4s owners about road noise
Hey Guys
i picked up a 2003 C4S,1 owner,23000 miles,had a PPI,checked out perfect,no accidents,when i started really driving the car i noticed lot of road noise that seems to come from the front,hard to explain(sounds like coffee pot perking fast,the rougher the road the louder it is,had a porsche tech drive the car he said he thinks its tires,i needed rears anyways so i put a set of Sumitomo HTR 111,noise is exactly the same so rule out tires,is this common with the 4S?,does the 4WD system transmit tire/road noise different?,just wondering if anyone has noticed this in there cars,i also have a 99C2 Tip and it is very smooth
any input appreciated Thanks
Albert
Albert
I have no strange noise from mine.
Nothing loose or rattleing around in the spare tire well?
I'd go back and have them check the front diff and maybe also change fluid.
There was also a post on here from a shop about a common problem with wheel bearings. Maybe have those checked.
Sorry to hear that. Possible stupid stuff: Loose jack or loose tool box or loose spare...
Check under and around the carpet in the front trunk...
You shouldn't have any rattling noise, for sure not metal-to-metal...
I have terrible road noise with Toyo R888 but quiet with Michelin PS2....
Good luck!
Good luck!
I too have an indeterminant noise -- though it's probably the Khumo Ecsta XS's wearing down (315, so wider than stock.)
porshe cs4 road noise
does the noise go away / reduce on a smooth road surface? My noise goes almost completely away on a smooth road. I have a lot of road noise, spoke to lots of experts, all think road noise from tyres. Yesterday I borrowed a set of wheels and tyres, still the same. The level is at times unbearable. The noise is so bad that the car will have to go and I will revertback to an "ordinary" model. Still investigating. Will post any news.
Where are you doing the majority of your driving in it? On the freeway, rural roads, city roads? I have the same car and setup except for tires; I have Pirelli P-Zero's on mine, and I only get a fair amount of road noise.
my noise also almost completely goes away on a smooth road,i think we have the same noise,does it sound like a coffee pot perking load and fast?,please keep me posted if you find anything,im also going nuts with this
Albert
Albert
road noise
has yourc4 had an accident, mine has, and i am beginng to suspect thats the reason some cars do not suffer from the problem and some do. Also, I have just been to Porshe dealership and newer models have a stainless steel stabiliser bar that conects the lower / outer bumper to the chassis, just in front of the exhaust baffeler. In the later models the rear bumper is therefore a lot stiffer, perhaps deadening the reverberation of noise. It would hurt to make two such bars and fit them.
Billy Bar
Billy Bar
I just bought a 02 C4S and on the drive home it was very quiet with no problems. The only thing I did notice was on grooved concrete between 74-76mph the tires made alot of noise. Anything under 74 was fine and anything over 76 is fine so mine is 100% tire related. My car has new Pilot sports up front and 1/2 worn PS2's in the rear.
Hi Albert, I am new to this web site, and unfortunately I can't send you a private message until I've made 15 posts? However, can you contact me somehow, as I have EXACTLY the same issue as you had explained . . In desperate need of your help, I would be much obliged.
G.
G.
