Speed control
Old Dec 24, 2009 | 07:38 PM
Goldduster's Avatar
Goldduster is infamous around these parts
Speed control
I have a 2004 C4S Cab and suddenly my speed control doesn't work. When I push the button on the stalk, it lights up on the dash, but won't set. Any recommendations are welcome?
Old Dec 25, 2009 | 12:05 AM
Ahmet's Avatar
Ahmet is infamous around these parts
I would start by checking the brake light bulbs, many German cars rely on properly functioning brake light bulbs for operation, as odd as that may sound. Also on occasion the clutch switch(es) and brake light switch can cause the cruise to not work...
Old Dec 25, 2009 | 03:36 PM
Goldduster's Avatar
Thank you, I'll check it out.
Old Dec 26, 2009 | 09:05 PM
Goldduster's Avatar
Checked out the brakes lights and they are working properly. Please advise how to check out the clutch and brake light switches. Other suggestions also welcome.
Thanks!!!
Old Dec 27, 2009 | 08:45 AM
carsareart's Avatar
carsareart is infamous around these parts
I checked mine on my BMW with a multimeter. They were inexpensive so I just replaced both switches and my cruise now works in that car.
Old Dec 27, 2009 | 01:59 PM
Omarcoolguy's Avatar
Omarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant future
mine doesnt work either...what switches did u check ?
Old Dec 27, 2009 | 02:09 PM
Goldduster's Avatar
? I'd appreciate a description of them, where they are at and what to look for. Hate to admit it, but I guess I'm clueless.
Old Dec 28, 2009 | 10:29 AM
Last Car's Avatar
Last Car is infamous around these parts
You will need to look up at the brake and clutch peddle shafts. You should see a little switch with a small 'pin' that should be touching the shaft. When you push the brake or clutch peddle the shaft will move away from this switch and break the ground....thus turning off (or not letting the Cruise to work if it's broken).
Good luck,
Old Dec 28, 2009 | 11:37 AM
Goldduster's Avatar
Thank you - This makes a lot of sense - I'll check this next.
Old Jan 9, 2010 | 10:20 AM
Goldduster's Avatar
Cool
Finally got around to checking the switches and found that the clutch switch was bad. I was a sport and for $11 each had them both replaced. Now it works, but only if I push the cruise botton with the lights off. I can set it with the lights on, if I push it initiatly with the lights off, but not if I try to set it after pushing the button with the lights on. Is there a reason it only works this way, maybe not using it at night, but that doesn't make sense either? Also, rechecked the lights and they all seem to work fine.
Old Jan 9, 2010 | 06:57 PM
RF5BPilot's Avatar
RF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really nice
Can't say in this case, but most of the absolute weird electrical problems I've had in the past were all due to bad grounds -- so electricity found odd ways to run through the system. You might see if you have a loose or bad ground wire.
Old Jan 9, 2010 | 07:14 PM
Goldduster's Avatar
Is there one ground or several. How would you recommend finding/fixing the problem?
Old Oct 13, 2013 | 04:41 AM
fullmetaljacket's Avatar
fullmetaljacket is infamous around these parts
Brake lights to FULL LED...
Hi guys. My cruise control / speed control light on the dash lights up when I push the cc on button but for some reason the cc doesn't work. It won't register a certain speed, increase or decelerate - nothing at all
I was searching and browsing around and found this post. Could this be my problem? I hope it is! I recently upgraded my tails with LED ones and the cc still worked then..UNTIL...I changed my 3rd brake lights to LEDs (2 assemblies: one on the wing and one outside). Suddenly, today, my cc won't work
Anyone who had this experience? Brake light bulbs were the culprit? Does this make sense?
Old Oct 13, 2013 | 12:01 PM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
You might try reversing the last light altering procedure and see does that cure the fault. If not then test the clutch and the brake switch independently.. I believe that you can bridge the two wires with a paper clip. If it works then its a bad switch right there.
Old Oct 14, 2013 | 03:00 AM
@Hurdigurdiman - Thanks! Appreciate it.
To update the thread, YES the culprit are the FULL LED bulb upgrade. I installed load resistors on each of my LED 3rd brake lights and voila - the Cruise Control / Speed Control is back! Maybe it's safety feature of the pcar not have the cc function when your brakes are faulty. Makes sense! Thanks angain! :-)
RallyBird
Oct 7, 2015 01:20 PM
Sales@RSW
Sep 3, 2015 09:34 AM
jyupitt1
Aug 31, 2015 12:58 PM
tkeck3
Aug 25, 2015 02:52 PM
