Need help determining if these 19" rims will fit
Old Mar 1, 2010 | 04:04 PM
sdpq's Avatar
sdpq is infamous around these parts
Hello, I am interested in purchasing some Carrera rims, the only problem I have is the part number listed seems to be for a Wide Body car which I do not have, however, the offset seems to be for a narrow body car, here are the details:
These are OEM rims, and I did do a search and the part numbers seem to be for a wide body car, and I even called the local Porsche parts and they stated the back wheels have a low offset therefore it would be for a WB vehicle, however, I told the seller where to find the offset on the wheel next to the air plug and he said the front is 57 and the rear is 67 which would fit the narrow body vehicle I believe.
Please let me know as I do like these rims but don't want to buy them only to find out they won't work, thansk.
2 Fronts
19 x 8 .Part # 997.362.156.03
235/35/19
2 Rears
19 x 11. Part # 997.362.162.03
305/30/19
Old Mar 1, 2010 | 04:55 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
The specs looks like its for the NB 997 which should fit fine on a stock 996 NB. Im not sure if it'll fit under a lowered 996 though. My only concern would be the rear tires. I believe the "correct" size(rolling diameter) would be 305/25/19 for the rear.
Old Mar 1, 2010 | 07:02 PM
sdpq's Avatar
hmmm, that may be a problem since I am on H&R springs...
Old Mar 2, 2010 | 06:51 PM
sdpq's Avatar
anyone else able to chime in?? thanks
Old Mar 3, 2010 | 05:37 PM
jmla's Avatar
jmla is just really nicejmla is just really nicejmla is just really nicejmla is just really nicejmla is just really nice
They'll fit, I would actually add 15 mm spacers to the fronts. I agree that a 305/25/19 would be a better fit for the rear. Just for reference, GT3 specs are: 18 x 8.5 - 40 mm and 18 x 11 - 63 mm. Some have managed to squeeze 12's with the right offset and rolled fenders, here's a pic of a 19 x 11.5 - 62 mm.
mikerosi
Dec 6, 2018 06:23 PM
RallyBird
Oct 7, 2015 01:20 PM
JayJayJohn
Sep 17, 2015 05:09 PM
richard181
Bentley
Sep 9, 2015 01:53 PM
