How to determine what spacers to use
Old Mar 16, 2010 | 06:46 PM
tarzancoe's Avatar
tarzancoe is infamous around these parts
Need to get spacers. But, not sure whether I need 5 or 7mm on front, and 15-18mm on rear, or even different withs. How can I determine this? Perhaps posting pics here? Is there a rule of thumb, measure points? Running 19's on 99 C2.
Old Mar 17, 2010 | 06:01 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
What offset are the 19's? For the factory 18's with offsets F 50mm and R 65mm,
7mm for fronts and 15mm for rears would make it nice and flush.
Old Mar 17, 2010 | 08:56 PM
tarzancoe's Avatar
A stupid question, probably: How do I find what the offset is?
Old Mar 17, 2010 | 08:59 PM
Airrik's Avatar
Airrik is infamous around these partsAirrik is infamous around these parts
check your manual.
Old Mar 17, 2010 | 09:07 PM
ebcarrera's Avatar
ebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to all
I have 15mm in back and 7mm in front. Stock rims which are 18 inch Sport Design rims with 285 in rear and 245 front.
Old Mar 17, 2010 | 09:48 PM
Omarcoolguy's Avatar
Omarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant future
i gave 1/2 inch spacers on my rear 265/30/19 i had to have the fenders trimmed tho, an 1/4 on my fron 235/35/19
it just gets to the edge, and is prob the best mod you can do for a great stance
Old Mar 18, 2010 | 11:41 PM
tarzancoe's Avatar
[QUOTE=Omarcoolguy;2767419]i gave 1/2 inch spacers on my rear 265/30/19 i had to have the fenders trimmed tho, an 1/4 on my fron 235/35/19
QUOTE]
That would be 7mm in front, and 12.5 in rear? My rear tires are not 265 but 245s. So, 15mm maybe?
Old Mar 19, 2010 | 09:48 AM
That would be 7mm in front, and 12.5 in rear? My rear tires are not 265 but 245s. So, 15mm maybe?[/quote]
yah alot of guys use 15mm , if ur car is lowered it might rub , but maybe not since your tires arnt that wide....but make sure you get some nice ones , the ones on my rear are nice beacause they bolt on and give me studs so its easy to ge the rear wheels on
Old Mar 19, 2010 | 11:44 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Those tires are too narrow for those rims... On a hard corner you could separate the bead from the rim very easily. Plus it's not protecting your rim from roads debris.
Old Mar 19, 2010 | 05:40 PM
U74sry's Avatar
U74sry is infamous around these parts
omar your rims are perfectly flush, looks great..
Old Mar 19, 2010 | 06:23 PM
tb996's Avatar
tb996 is infamous around these parts
Look on the wheel next to the valve, should give width and offset
TB
Old Mar 19, 2010 | 11:50 PM
tarzancoe's Avatar
No offset indicated on rims. I am running 275/30/19 in rear. 235/35/19 in front.
Old Mar 20, 2010 | 06:02 PM
99C2's Avatar
99C2 is infamous around these parts
Spacers:
I have a set of 7mm Spacers and ther proper bolts - in box never mounted - for sale! I even have a new front Bra and side mirror too if anyone is interseted....
99C2
Old Mar 21, 2010 | 09:56 AM
tarzancoe's Avatar
Originally Posted by 99C2
Spacers:
99C2
Did you run those in yoru c2? with what tires?
Old Mar 22, 2010 | 04:39 PM
99C2's Avatar
Turbo Twist Rims 18" stock - I had the 14mm in the rear and never had time to put the 7mm in the front. I found that just the 14mm in the rears gave the NB a wider look.
99C2
