Wheel offset and width question?? Again
Old Apr 25, 2010 | 11:06 AM
nijoma's Avatar
nijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud of
Anyone running wb 997 wheels on a nb 996? 19x11 rear et51? If yes what tire size?
Old Apr 25, 2010 | 11:43 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
19 by 11 with an et51 is going to stick out way too much. I'd look for a et63-67 ish wheel for a 11" width.
Old Apr 25, 2010 | 11:45 AM
geetee's Avatar
305/25/19 should fit fine btw on a 11
Old Apr 25, 2010 | 12:06 PM
GT3Gavin's Avatar
GT3Gavin is infamous around these parts
I have had the 997 turbo 5 spoke wheels on my car before and it was perfectly lined up with the fenders. I'm not sure of the offset but they were OEM not reps.
19x11 315/30/19
Old Apr 25, 2010 | 02:55 PM
HIGHcard's Avatar
HIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud of
My friend with a 996 GT3 is running 19x11's +50 w/ 295/30/19's..The wheels/tires are lined up RIGHT with the fenders..I would imagine that any 996 narrow body would be able to pull off the same wheel/tire setup with rolled fenders and 996 GT3 alignment specs..
Old May 21, 2010 | 09:36 AM
sardmd's Avatar
sardmd is infamous around these parts
Nijoma - did you ever do the upgrade? And if so how was the fitment?
Old May 21, 2010 | 10:55 AM
nijoma's Avatar
Yes
I am running 19x11 with an et 52 with 315/25/19 and they look great and barely stick out. I have no issues and it looks great.
Old May 21, 2010 | 11:09 AM
0100's Avatar
0100 is infamous around these parts
What year is your 996, and any pictures?
Old May 21, 2010 | 11:17 AM
sardmd's Avatar
did you have to roll the fenders or doe sit clear - mine has a pss9 coilover so i am hoping it should not need a fender roll
Old Jun 3, 2010 | 09:01 PM
george996's Avatar
george996 is infamous around these parts
i am in the market for new wheels for my 996 nb and have been doing some research. The only tire with close to the correct overall diameter that fits an 11" is 305/25-19. The problem is there are only one or two tires to choose from and they are pricy. Also, i think the an et of 51 may be too aggresive. i agree with geetee about the et.
Old Jun 3, 2010 | 09:12 PM
0100's Avatar
Not perfect, but a 295 30 19 will work no problem.
Old May 31, 2021 | 07:22 AM
ttboost's Avatar
9" min width in front and 11" min width in back. Front ET's can be anywhere from mid 50's (stock) to mid 40's. Rears can be from low 50's (stock) to mid 30's. I have 11.5 rear with about a 35mm offset. Pokes and bit, but still deciding if I like it. I may reduce from 10mm to 7 or 5, not sure yet. Front is perfectly flush, no rubbing.
Perkman87
Nov 19, 2015 05:31 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
