please help!!
Old Jul 2, 2010 | 01:51 PM
ohdavey6286's Avatar
ohdavey6286 is infamous around these parts
please help!!
My key will not go into m ignition and I'm not sure what is going on. The steering wheel is not locked.please help I am stranded!
regards,
david currie
Old Jul 2, 2010 | 02:01 PM
John L's Avatar
John L is infamous around these parts
bad ignition switch, wiggle it and gently persuade it to get in there, it should and then you probably won't be able to get it out. Very common problem on these cars, I beleive the replacement is actually an audi part that can be had on ebay very cheap. you may also have no headlights or other electrical gremlins while it's malfunctioning so be careful. The DIY is there if you search.
Old Jul 2, 2010 | 10:19 PM
MkC2S's Avatar
try pushing it in & wiggle it a bit..it'll eventually go in...same thing if your're trying to pull it out...you will need to replace the ignition switch..
If you're mechanically incline, the parts are cheap like $12-$15(ebay) & DIY are easy peasy...here'a a link for DIY
http://industryfigure.com/berkeley/P...tionswitch.htm
It's say for boxster,but they're the same parts..
Is there an ignition switch bug going on...there sure is alot of post about this..maybe we should start a thread specifically for this.
Old Jul 3, 2010 | 06:10 AM
Raym50's Avatar
Raym50 is infamous around these parts
Yup - That was my problem. A/C went out, then the keyfobs went out and I had a hard time getting the key in and out. I used WD40 on the key for a few days which certainly helped. Finnaly sucked it up and replaced the ignition switch at dealership for around 750. Hopefully you can DIY as posted by others for A LOT less.
If anyone in brooklyn NY wants to take me under their wing and teach me how to do some of the mods myself (change stock radio for navi screen, replace steering wheel and shifter and change the interior trims) - I will stock your home with the rest of the summer's supply of beer!
Old Jul 3, 2010 | 10:25 AM
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
DANG...Raym how come you gota bee so far. I GOT A BIG EMPTY 2nd FRIDGE... well not empty yet but it will be after sunday....LOL
