18's in the Front and 19's in the Rear
Old Aug 4, 2010 | 03:13 PM
gswc32's Avatar
gswc32 is infamous around these parts
Has any one use this set up? Will it cause any performance issues?
Old Aug 4, 2010 | 03:34 PM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
Don't think it will work... the computer will trip out due to difference in diameters between front and rear tires.
Old Aug 4, 2010 | 03:43 PM
Slider's Avatar
If you do the math and check tire sizes, the diameters to make sure they are within acceptable limits, the computer should not know what's going on. Having said that, I don't know if it would cause handling issues at high speed. The amount of flex in the tires would be different between the front and back.
Old Aug 4, 2010 | 11:07 PM
Grant P's Avatar
Grant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of light
I id would call your local dealer, and talk to a service guy they are usually pretty good
Old Aug 5, 2010 | 08:41 AM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
Why would you do this?
Old Aug 5, 2010 | 09:41 AM
Zookie's Avatar
Because its Very Corvette'ish :P
If you are is RWD and no PSM you should be fine. Regardless just make sure Front and Rear Tires are Within 3% Diameter Diffrence
Old Aug 5, 2010 | 09:47 AM
gswc32's Avatar
I assume better performance. I've seen several cars(not Porsche) with this set up / staggared look. Aesthetic wise, It would be a broader stance.
Old Aug 5, 2010 | 01:06 PM
x1kc's Avatar
x1kc is infamous around these parts
i believe Lotus Exige and Elise all run 1'' smaller front (ie. 16" front 17" rear)
as long as it is 3% difference in diameter you should be fine.
post some pics when you get it done tho
Old Aug 5, 2010 | 01:11 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
corvettes...and even lambo....there's some really nice lambo's with 19/20 or 20/21 setup's ...go check out the lambo section
as long as the overall diameter's within spec...no problem...handlingwise? I don't know
Old Aug 9, 2010 | 05:39 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
I guess if you really wanted to you could do 225/40/18 in the front and 275/30/19 in the rear if you have a 996, if you have a 10.5 wide or more you can even do a 305/25/19 or 315/25/19 in the rear given an off-set of 50+
-Eli
Old Aug 9, 2010 | 05:58 PM
GT-S's Avatar
GT-S is infamous around these parts
Remember, cars that come stock with larger rims at the rear are made for a setup like it - Porsches are not.
Old Aug 9, 2010 | 06:52 PM
The 996 is not made to use 19" either but more than 50% of the guys are running 19"......
-Eli
Old Aug 11, 2010 | 04:13 PM
gswc32's Avatar
Isnt the 997 on 19's? What's the difference?
Old Aug 11, 2010 | 04:27 PM
Making a point but ~ Yes the 997 comes stock with 19" but the 996 does not, the 997 is also designed to accept 26" OD on the wheels in the back where the 996 is 25 OD all the way around...
-Eli
Old Aug 12, 2010 | 07:01 PM
Airrik's Avatar
Airrik is infamous around these partsAirrik is infamous around these parts
-Eli
I see interesting hmmm... so do 19's throw off the grip and handling a little bit?
audipwr1
Sep 25, 2021 01:31 PM
2lflat4
Nov 18, 2019 05:05 PM
COBB Tuning
Nov 9, 2015 08:02 PM
TrackOne
Aug 20, 2015 12:56 PM
cab83_750
Aug 19, 2015 12:37 PM
