Dash Door Lock Switch
Old Aug 9, 2010 | 06:58 AM
JohnnyV1's Avatar
JohnnyV1 is infamous around these parts
2002 996 C-2, 6-speed.
The switch fell out into the dash.
Any one know how to remove the dash panel that holds that switch & the others, does it pop off?
Old Aug 9, 2010 | 07:06 AM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool
The horseshoe right?
Yes it just clips in. Take something plastic like a credit card and gently pry at one corner. It will pop off.
Switches clip in from the back.
Old Aug 9, 2010 | 01:20 PM
JohnnyV1's Avatar
Dash switch
Yes the horseshoe.
Thanks I'll give it a try.
I'll let you know
Old Aug 10, 2010 | 04:46 PM
davebho's Avatar
davebho is infamous around these parts
pull baby pull :)
http://www.macarbon.com/install_guid...stallation.pdf
instructions above, just be gentle
Old Aug 10, 2010 | 06:10 PM
JohnnyV1's Avatar
Dash switch
All fixed,
I used a plastic putty knife to gently pry away the bottom right corner. I was able to get at the switch & pop it back in to place. It seems secure.
Thanks to all that responded, it was helpful and it worked.
JohnnyV
Old Aug 11, 2010 | 12:52 AM
Grant P's Avatar
Grant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of light
You need an easy button
adnanm3
Nov 22, 2023 02:43 AM
NC 996TT
Mar 23, 2023 06:19 AM
NIKAS
Aug 20, 2019 07:53 PM
keeperofbeasts
11
Apr 3, 2017 10:53 AM
sparks
Sep 8, 2015 03:03 PM
