Synthetic Oil
Synthetic Oil
2001 996 for reference.
Has anyone ever replaced their oil with 5W-30 Mobil1 Synthetic Oil?
What are the cons by using this viscosity instead of factory recommendation
0w40 (thick oil) Pros:
1)Porsche approved - peace of mind
2)Better film strength, less wear in high temp high pressure situations
3)Meets ACEA A3 standard
4)Higher idle oil pressure
5)Lower oil consumption
5w30 (thin oil) Pros
1)Better gas mileage
2)Quicker flow at startup= less wear?
3)More readily available (Walmart is dropping 0w40)
4)New Mobil 1 "Extended Protection" version available with higer additive levels
5)New version of 0w40 (new bottle) apparently has LESS additives to meet the new US "SM" requirements
6)Higher oil flow rate of thinner oil may cool better
EDIT: Some of the new Mobil oils are using Antimony based additives. This may be why the new Mobil 1 0w40 appears to have less antiwear additives. The oil analysis I saw did not test for Antimony.
Viscosity at various temps. GC= German castrol. Note that even though 0w40 has a lower cold temp rating, vs the 5w30, it's thicker at all temps down to -20C.
The 5W-30 is more readily available and it is a thinner oil viscosity.
I know local store carry 0W40 but wanted to know if anyone ever used this grade.
I don’t drive my 996 in the winter so the concern of low temperature statistics wouldn’t apply.
http://www.mobil1.com/USA-English/Mo...s/Mobil_1.aspx
I wouldn't go lower than 40W on the high side. Get a 10W -40W or 15W - 40W. If I didn't have a blower I my car, trhere would be no way I would run a 0W - 40W. I would be back to 10W or 15W - 40W.
Originally posted by ebaker
A Technical Service Bulletin dated 2/2004 says to use any synthetic ACEA A3 rated, 0w40, 5w40, or 5w50 oil. Below -12F temp use 0w40.
I use 5w-50.
You modified guys should be on 5w-60.
http://www.ows.com.au/products_lubricants.html#5w50
might as well use the best.
Originally posted by carbonissimo
I use 5w-50.
I use 5w-50.
Well.. I have to agree that SC motors need the best.... I mean mobil 1 is superb but if your running that kind of horsepower I hear MOTUL is the best around... has great heat absorption properties... better than Mobil 1 synthetic for just a bit more.
The SC guys here in Toronto swear by MOTUL.
just an observation.
