Car wouldn't start for a while...after a few cranks then it did. HELP???
Old Oct 19, 2010 | 10:19 AM
rrrruben's Avatar
rrrruben is infamous around these parts
Originally Posted by Nine_Eleven
Thanks rrrruben, I hope it's the battery. Which is easy fix. BTW is your E55 silver and do you have a 944?
It's Brilliant Silver Metalic. W210 2000 E55 AMG.
Old Oct 19, 2010 | 10:22 AM
rrrruben's Avatar
Originally Posted by split
its a good thing i live in canada, where its always cold
You should be so lucky.
Old Oct 19, 2010 | 12:36 PM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
I have heard from a mechanic that the CPS would only make ignition click?
Old Oct 20, 2010 | 01:48 AM
This is where my battery meter at idle.
Old Oct 20, 2010 | 02:14 PM
I will go to autozone to get the battery check.
Old Oct 20, 2010 | 03:44 PM
GT3 Chuck's Avatar
Administrator
good idea...the pic shows that your alternator is working and the system appears to be charging...doesn't mean your battery can hold cranking amps
Old Oct 21, 2010 | 01:27 AM
When it's in "ON" position, it's on 12 not 14. Then when I crank it, it goes all the way down to 10...
Old Oct 23, 2010 | 04:33 PM
So it turned out to be my battery, I was stuck again and then somebody jump start my car. The battery was on 13 when it was being jumped and I cranked it, it only went down to 12 instead of all the way to 10....
Old Aug 17, 2014 | 04:45 PM
JG GT500's Avatar
JG GT500 is infamous around these parts
I am experiencing this issue. Cold start - no problem, hot start - sometimes will not start on first try. Will start on second attempt. But, This weekend, started hot or cold every time. Battery is from 11/12. Going to charge it tonight. Connections look good.
Old Aug 19, 2014 | 07:30 AM
JG GT500's Avatar
Charged battery. Took a long ride. Stopped and started hot 3-4 times. No problems - full crank start each time. Will get battery tested when I have a chance.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
Sep 1, 2015 03:16 PM
DSCOFF
Aug 23, 2015 01:22 PM
Aug 20, 2015 12:17 PM
