Car wouldn't start for a while...after a few cranks then it did. HELP???
Old Oct 18, 2010 | 06:34 PM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
I was at a shopping store parking lot. When I was ready to leave, started the car. It wouldn't crank all the way. Half way I'd say.... I kept trying and trying...after about 10 cranks and then once it's ON position i tap the gas pedal a bit...then crank it...it started.. What could be the issue..? Please help Thanks!
Old Oct 18, 2010 | 06:36 PM
GT3 Chuck's Avatar
Administrator
battery, starter solenoid or starter motor...most likely battery
Old Oct 18, 2010 | 09:17 PM
How do I diagnose if it's the battery? I mean when in "ON" position it will show all the gauges lights such as (oil,cel,seatbelt,etc.) If it's the battery it wouldn't show those lights would it?
Old Oct 18, 2010 | 09:21 PM
GT3 Chuck's Avatar
Administrator
sure it would...just won't have the cranking amps necessary for a good start...the factory batteries in these cars are not very good imo....go to an O'Reilly or Autozone and they will test it for free
Old Oct 18, 2010 | 09:49 PM
white99c2's Avatar
white99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of light
It is the slow death of the 996 starter. My car is doing it too. You think its the battery but the starter is turning very S L O W. Is it worse when the engine compartment is HOT?
Old Oct 18, 2010 | 09:54 PM
rrrruben's Avatar
rrrruben is infamous around these parts
Just a gut feeling: crank position sensor. A worn CPS will not operate properly once it heats up ( a trip to the store). Yet, on a cold start will fire up almost every time. If your P-car starts first try in the morning, the CPS may be suspect. Good luck.
Old Oct 18, 2010 | 10:28 PM
996c4s4dailyuse's Avatar
996c4s4dailyuse is infamous around these parts
My guest would be crank sensor have it scanned for codes check live data crank and see if you can see the crank sensor signal!! The sensor can also be tested for the right ohms!
Old Oct 18, 2010 | 10:34 PM
996PCarGo's Avatar
996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold
Maybe the starter... battery... or loose connection?
Hard to diagnose via forum post.
Old Oct 18, 2010 | 10:42 PM
Thanks guys for input. It gives me an idea which to target first. Which is the battery... then starter... Again thanks. If it happens again I will post a video for you to share.
Old Oct 18, 2010 | 11:02 PM
I just started my car in the garage after about 4-5 hours parked. It started fine now. Some one mentioned when the engine is hot it's difficult to start. I never had a problem starting it the first time of the day.
Old Oct 19, 2010 | 12:18 AM
Ahmet's Avatar
Ahmet is infamous around these parts
Though it's hard to say conclusively here, it sounds like the starter is the culprit.
Old Oct 19, 2010 | 12:29 AM
GT3 Chuck's Avatar
Administrator
well, as suggested the crank position sensor is also a very possible culprit...there have been members here with the same issue...if the battery is strong and the car cranks strong and starts easily when cold but not when hot then the cps is also a likely candidate and an easy fix..the starter motor is much more expensive...if it turns out to be the starter replace the cps while you are there.
Old Oct 19, 2010 | 12:35 AM
rrrruben's Avatar
That would be me. I had a similar issue with my E55 AMG. She fired up cold, but hot was a gamble. I replaced the battery of no avail. I replaced the CPS (crank position sensor), and she fires up every time...hot or cold. Nonetheless, pull the codes to hone in on this issue. Keep us posted.
Old Oct 19, 2010 | 12:49 AM
Thanks rrrruben, I hope it's the battery. Which is easy fix. BTW is your E55 silver and do you have a 944?
Old Oct 19, 2010 | 09:41 AM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
its a good thing i live in canada, where its always cold
