Oil level getting low
Old Mar 2, 2005 | 06:16 PM
QuickSilver's Avatar
QuickSilver is infamous around these parts
Unhappy Oil level getting low
Recently, I found the oil level getting low quickly.
About 6 months ago, it was right at the middle after the measurement done.
Probably 2 months ago, it had 3 bars left.
Last week, there was only 1 bar left........
The '03 C4S is 4500 miles.
I did not change the way I drive it during the past whole year.
I remember there were some discussion about "oil burnt out" and some owners need to add oil periodically?
I've never found any single drop of oil on the ground. Where is my oil
Is this normal? If it is, what should I get to fill it up? Any recommendation?
Thanks.
Old Mar 2, 2005 | 06:18 PM
My87Targa's Avatar
My87Targa is infamous around these parts
if its getting burnt then thats why you dont get a drop. just add as needed or get your car checked out
Old Mar 2, 2005 | 06:20 PM
TT Surgeon's Avatar
Same thing happens in mine, no smoke, no drips. Also an '03 C4S.
Old Mar 2, 2005 | 08:42 PM
joekimdds's Avatar
joekimdds is infamous around these parts
same with me....'04 c4s...around 3-4000 miles, had to add 2 qts....no drips or oil spots....same thing happened with my friends...around the same mileage and same car...took it to the dealership...found no problems
Old Mar 2, 2005 | 08:44 PM
joekimdds's Avatar
use mobil 1 (i think it was 0w-40 the european version)
Old Mar 2, 2005 | 09:06 PM
stiles_s's Avatar
stiles_s is infamous around these parts
You haven 't added oil to your car in 6mos?! Keep the oil level up.
Also, if you read your manual, you'll see that oil use can vary. In particular, you'll use more oil if you go on a longer trip after a bunch of short hops -- it burns off any/all moisture which in effect lowers the amount of oil.
Old Mar 2, 2005 | 11:59 PM
WARDHOG's Avatar
WARDHOG is infamous around these parts
If your engine is using 1 Qrt every 600 miles, you may have a problem and the dealer should get involved. Other than that, keep you eye on the oil as you should like you would with your tire pressure. Check it every week via dipstick. Gotta love these C4Ss.
Old Mar 3, 2005 | 06:11 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
Cool
Doesn't sound too bad.
Just add a little and keep an eye on it.
Don't bother calling the dealer, they'll only say that's normal.
Old Mar 3, 2005 | 09:16 AM
TT Surgeon's Avatar
Mine uses a qt every 1500-2000 miles, I drive it 'hard' though. Dealer found nothing wrong last time in the shop. Switched to a thicker oil this winter and the oil usage dropped dramatically. One thing I did was to make the dealer put it in my service record that I complained of oil usage, found to be normal. Strangely, he would only do that after performing a compression check, which was normal.
I don't think that C4S's have a particular problem, perhaps we drive our cars harder!
Old Mar 3, 2005 | 02:00 PM
Smile
Guys, thank you all for the reply. Now I feel better
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
riverflyer
Sep 1, 2015 04:22 PM
tkebp1275
Aug 31, 2015 06:35 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
