RS engine mounts -- WOW!
Old Oct 28, 2010 | 04:33 PM
jr2's Avatar
jr2
jr2 is infamous around these parts
Just had the first drive after having the RS engine mounts -- WOW! Rock-solid feel, esp going over bumps, and meshes well with the ugraded suspension (PSS9/GT-3 sways/links).
Well worth the $400 for the parts from Suncoast and $144 labor charge from my independent.
Stock hydro-elastic mounts had some wear but did the change for the upgrade rather than out of any necessity.
Old Oct 29, 2010 | 09:21 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
i have solid engine mounts and i def like them more than my stock ones
Old Oct 29, 2010 | 09:23 AM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
what kind of feel they give you over the oem?
Old Oct 29, 2010 | 10:33 AM
jr2's Avatar
jr2
less flex over bumps, shifter seems more directly connected (also replaced the stock plastic linkage with an aluminum billet linkage), cornering seems more composed
best way to say it that car feels more like a single block of metal -- more of a "unified" feel of driving one solid mass instead a bunch of parts screwed together, if that makes any sense
Old Oct 29, 2010 | 10:47 AM
gu9cci's Avatar
i see...that is answer i want.any negative site?
Old Nov 2, 2010 | 11:07 AM
SuncoastParts's Avatar
SuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond repute
Great feedback, this seems to be the common impression of the RS motor mounts. Glad you're enjoying them.
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow us to stay connected:
Join Our Newsletter | Facebook
Old Nov 2, 2010 | 02:32 PM
gu9cci's Avatar
any diy?
Old Nov 2, 2010 | 03:30 PM
jr2's Avatar
jr2
any diy?
Not by me -- my indy does all!
Old Nov 28, 2010 | 05:23 PM
CWhaley's Avatar
CWhaley is infamous around these parts
they really do make a world of difference with the car.
Old Nov 28, 2010 | 09:40 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
Ya I love mine... I did them along with all my suspension work, wheel and tire change, and light weight flywheel and new clutch.
Talk about a new car...
Cheers
Aaron
Old Nov 29, 2010 | 07:50 PM
Rezaroy's Avatar
Rezaroy is infamous around these parts
How long was the install and was it difficult
Old Nov 29, 2010 | 07:58 PM
CWhaley's Avatar
Should only take about 1 to 1.5 hrs of work. With a jack and standard tools you should be able to hanlde this job.
Old Dec 6, 2010 | 06:00 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Do the RS motor mounts make that much of a difference? Especially on a tip?
I'll be doing power steering pump along with redoing the exhaust again so I'm thinking might as well do the mounts also.
Old Dec 6, 2010 | 08:10 PM
CWhaley's Avatar
The mounts will make a significant improvement.
Old Dec 7, 2010 | 10:56 AM
Dervish's Avatar
Dervish is infamous around these parts
http://p-car.com/diy/motormount/
For the 993 but effectively the same process, easy DIY...
