Battery?
Old Nov 1, 2010 | 10:06 PM
Grant P's Avatar
Grant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of lightGrant P is a glorious beacon of light
Battery?
So sometimes when i start it up it seems like it turns and pauses, and then starts then going all the way through...does this mean the battery is going out? Or something else?
Old Nov 1, 2010 | 11:18 PM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
YES! I just had that problem..... Go to Walmart and look for Size 48 875 cranking amps 700 cold cranking amps battery for $77.00 you get 3 year warranty.
Everything else is working in the car but when you crank it, it cranks but not enough voltage to start the engine. I just replaced mine a couple of days ago...
It usually happens when you turn off the car numerous times in a small amount of time such as errands.... stop here stop there..
When you crank it does the needle (battery/alternator) on you gauge go from 12 to 10 sometimes below 10?
Old Nov 2, 2010 | 12:44 PM
Grant P's Avatar
Exactly, mine currently still cranks but it pauses for about 1 second or 2 and then starts...
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
