Passenger window doesn't go down/up when opening the door to prevent hitting.
Old Jan 13, 2014 | 01:33 AM
nanoc15's Avatar
nanoc15 is infamous around these parts
Fixing the regulator unit for less than $10
Hi all.
I have a 2001 996 C2. I just replaced the entire wire on the regulator for less than $10. I think instead of throwing away a good unit (regulator bracket and wheels) and paying more than $200++ just for part is insane when only the wire is broken.
I also did the other window (wire) some K miles ago and it works great.
I must admit that im really not a tech guy but i searched the web and forums for instructions on how to replace the regulator and when i had that out i just decided on replacing the wire as everything else was good.
So if i can do it - everybody else can too
Old Jan 13, 2014 | 02:24 AM
tokyopav's Avatar
tokyopav is infamous around these parts
Nice work. Any photos?
Old Jan 13, 2014 | 02:35 AM
nanoc15's Avatar
Hi thanks. No - unfortunately i didnt take any. But there are a lot of youtube videos and guidance on the forum for removing the regulator. When the regulator is out you just go to your local hardware store and buy the wire, some wire clamps and tin to solder the ends.
I used a 1.6mm wire instead of the 1.5 mm OEM. And if u just look at the regulator and understand the function its just a little patience and time. The main thing is to keep the wire very streched when fitted into the green wheel on the regulator motor.
Old May 30, 2014 | 02:42 PM
dantm's Avatar
dantm is infamous around these parts
Hi guys, Boxster owner here -- a few days ago the passenger side window stopped going back up when the door is shut...
It does go down when the door is open but somehow (I guess) it doesn't sense the door being closed again.
What are the steps to troubleshoot?
Old May 30, 2014 | 07:06 PM
jjmullen's Avatar
jjmullen is infamous around these parts
Anyone have a grinding sound happen when operating the window up & down? This just started for me, passenger window. So if its all the way up, close the door, it doesn't drop. If I power it down or up, its making a grinding noice. Regulator? I started to pull the door panel, but I found it difficult to pull out near the airbag. Appreciate the feedback.
Old May 31, 2014 | 09:46 AM
Dennis C's Avatar
Grinding noise is a symptom of a failing regulator. Both of mine did it before they failed.
Old May 31, 2014 | 10:56 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Probably as you've read in this, and other, threads it's your window regulator. Simply replace it.
Old Jan 14, 2015 | 04:47 PM
freebirdbeachbum's Avatar
freebirdbeachbum is infamous around these parts
I know this is a recurring issue and topic but what do you think about this?
My passenger window moves up and down as its supposed to but only a fraction of what is needed so it seems to me the microswitch is fine. I've done the battery disconnect move but it didnt work. Otherwise the window works perfectly. Any thoughts?
Thanks in advance.
Old Jan 14, 2015 | 06:07 PM
rrrruben's Avatar
rrrruben is infamous around these parts
Thanks in advance.
I recently had the same experience. It would appear that the window regulator cable is beginning to fail. Replace the window regulator. It will eventually completely fail.
Old Feb 27, 2018 | 09:56 AM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
I have a similar issue with a chattering from the window motor when the passenger door is closed the first time. This is on a 2001 996TT new purchase a few days ago. All issues described on the passager door.
The second issue is the interior light is not working at all with this door open.
I took the door panel off to fix what i though was a micro switch problem, after taking the panel off the window started lowering again! Tested each micro switch over 30 times with a meter and they were solid.
As most of you have already guessed,everything worked for a few minutes after I put the panel back on and not it’s not lowering again.
Any thoughts??? Micro switches are good on the (2) handles Is it the latch? guessing so as the interior light not working at all from this door.
J9277655
Dec 28, 2015 11:01 PM
RallyBird
Oct 7, 2015 01:20 PM
Sep 1, 2015 03:16 PM
richard2966
Bentley
Aug 22, 2015 03:33 PM
