Brief Drivetrain Noise During a Trackday...
Old Mar 25, 2011 | 05:27 PM
02C4S's Avatar
02C4S is infamous around these parts
I have an '02 C4S and I attended a track day last weekend. During one of my runs I got my car loose and to get out of it applied some opposite lock and jumped on the throttle. At which point a somewhat nasty groan/harmonic came from the drive train during the slide. The motor didn't bog or rev, I felt nothing in the steering wheel and ran two more laps that session without feeling anything different.
I ran the car for another session as well and drove it home without feeling anything different. I believe I had the PSM off, but I forgot to check after the run.
Any ideas on what it could be. The clutch as 30K on it and is a bit soft.
...Joel
Old Mar 25, 2011 | 06:12 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
Shot in the dark, have you replaced your motor mounts ever?
They are filled with fluid and mine leaked and had to be replaced after I jacked the car once. Went with GT3RS solid mounts.
My thought here was the engine may have tilted a little more than designed, but not enough to be permanent.
Again... shot in the dark...
Cheers
Aaron
Old Mar 25, 2011 | 09:59 PM
TT Surgeon's Avatar
Antilock brakes?
Old Mar 26, 2011 | 01:34 PM
02C4S's Avatar
I'm thinking it was something to do with the PSM, but I believe I had it off at the time, but I forgot to check when I pulled in.
I didn't think the ABS would be that noisy and it really happened after I jumped on the throttle.
...Joel
Old Mar 29, 2011 | 04:49 AM
GREERJ1's Avatar
GREERJ1 is infamous around these parts
Regarding the antilock brakes, did you feel anything from the brake pedal. When the antilock brakes engage, it feels like a shudder on the foot and definately a groan. It gould have been the viscous coupling to the front. If the rears are spinning and the front is not, something has to give.
James Greer
Old Mar 29, 2011 | 09:33 AM
02C4S's Avatar
James,
I was just off the brakes transitioning the car when the car broke loose then stabbed the throttle so I'm not sure if there was any feedback in the brake pedal. My thought was also the viscous coupler, but the groan sounded like it came from the rear of the car and I believe this is up front.
...Joel
Old Mar 29, 2011 | 06:00 PM
02C4S's Avatar
Just to add to this for future reference on here I talked to a local shop here in Orange County and they attribute it to the LSD in the rear.
...Joel
Perkman87
Nov 19, 2015 05:31 PM
Oct 2, 2015 02:23 PM
rob4wellness
Oct 2, 2015 07:32 AM
Ronny-
Sep 30, 2015 07:30 PM
