one bad coil and spark plug tube leaks oil
Old May 3, 2011 | 03:58 PM
Storch's Avatar
Storch is infamous around these parts
I have one diagnosed bad coil that will cause a missfire at times.
I think I should just buy all 6 for $250 along with plugs, i also have an oil tube that leaks right onto the exhaust header, makes a smelly mess, is this common, should i have them all replaced?
Old May 3, 2011 | 05:20 PM
Axeman's Avatar
Axeman has a spectacular aura aboutAxeman has a spectacular aura aboutAxeman has a spectacular aura about
What year is your car?
Old May 3, 2011 | 06:03 PM
Storch's Avatar
1999
Old May 3, 2011 | 06:27 PM
Axeman's Avatar
The coils do go bad I would change them. I have an extra set (brand new) if you need them. Which oil tube are you talking about, haven't heard of that being a common issue..
Old May 3, 2011 | 07:00 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Leaks at the spark plug tubes are not uncommon. If you are in far enough to replace the coils (and the plugs I hope) then the tubes are an easy fix.
Old May 3, 2011 | 07:07 PM
fast996's Avatar
fast996 is infamous around these parts
how much are new coils? i need to do spark plugs too
Old May 3, 2011 | 08:22 PM
Storch's Avatar
I did order the coils, got the set on Ebay only $210
Old May 3, 2011 | 08:30 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Change the spark plug tube seals every time you change the plugs. It only adds about 30 bucks in parts and a few minutes of extra labor.
Old May 3, 2011 | 10:19 PM
pmkazz's Avatar
pmkazz is infamous around these partspmkazz is infamous around these parts
Karl,
Reading your blog, it appears that you use a transom plug to remove the tubes versus the Porsche tool. So, I gather you would recommend the transom plug as a remover in place of the Porsche tool which is a little pricey?
Thanks,
Peter k
Old May 4, 2011 | 09:00 AM
Dharn55's Avatar
A transom plug works as good or better than the Porsche tool at a fraction of the cost.
Old May 4, 2011 | 12:26 PM
alpine003's Avatar
$1.99 at your local Menards. I found this out after I ordered one online for nearly 10x the price.
I do agree about replacing o-rings anytime you do spark plugs. However, you should check the tubes themselves for any cracking.
Old May 4, 2011 | 01:34 PM
Originally Posted by pmkazz
Karl,
Thanks,
Peter k
Yup! You can get them at any boat shop as well. I "think" mine is a 1", and it wrapped electrical tape around it 2-3x as it was just a shade too small to get a good grip. IIRC it was less than 10 bucks.
Yup, check for cracks as well. It is pretty rare to have a tube crack, but I have seen them on occasion. I keep a couple of tubes on hand just in case, but I think the same ones have been sitting in my toolbox for at least 2 years, and I've done a lot of seals in that time.
Old May 10, 2011 | 06:54 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
I used a 1 1/4 transom plug and shaved it down with a dremel. Do them all so you have piece of mind. It's a fairly easy job to do. Great write up on Renntech.org on how to do it.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Highlander
Aug 23, 2015 09:05 PM
magoochi
Aug 23, 2015 05:54 PM
