washing advice for convertible top
Old Apr 4, 2005 | 09:13 AM
RobertM's Avatar
RobertM is a glorious beacon of lightRobertM is a glorious beacon of lightRobertM is a glorious beacon of lightRobertM is a glorious beacon of lightRobertM is a glorious beacon of light
Question washing advice for convertible top
When washing a convertible, what does everyone do???
I usually wash the top with the same soap and wash mit and then dry with the Absorber (every other week). Most of the time I will not use soap on the top.
Old Apr 4, 2005 | 12:48 PM
schnellerm3's Avatar
schnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant future
I've been reading this guide in preparation for taking delivery of an S2000 - never owned a convertible before.
Autopia guide
Old Apr 4, 2005 | 02:37 PM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
Dont wash with the soap. just rinse it with water, if their is a spot or a dirt spot, use a convertible top spray cleaner. I heard using the car soaps will deterioate the bond to repel water. Dry just with a micro towel.
Old Apr 4, 2005 | 03:10 PM
keoni1978's Avatar
keoni1978 is infamous around these parts
I would spray it with water and run my hand over the top. Soap will ruin the water repellent.
Old Apr 4, 2005 | 05:07 PM
Orient Express's Avatar
Orient Express is infamous around these parts
Here is the process that I have been using for 20 years on canvas tops, and it has worked well for me.
Clean with Porsche convertible top soap. Wash by hand with a kitchen sink brush, (soft nylon bristle type). Gently scrub using the brush. Rinse with clean water from the hose.
Next, get the car in the shade so the water won't dry. Use a shop vacuum and suck off the water, and any soap and dirt residue. A towel can be used to blot up the water, but all towel will leave lint to some extent, even microfiber towels.
Twice a year, spray the top with Porsche top protectorant, or green can scotchguard.
Use a lint roller and a shop vacuum in between washings to get off the dirt.
Old Apr 5, 2005 | 07:45 AM
Greg L.'s Avatar
Greg L. is infamous around these parts
Another product you should consider is Raggtopp. They make a cleaner and a protectant.
Old Apr 6, 2005 | 03:53 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
The Raggtopp product is the best. Use the cleaner and then the protectant. Its easy and when you are done, the top will bead up like a highly waxed car. You should also buy the lint-free cloth to push the water off the top when you wash it.
Old Apr 13, 2005 | 07:08 PM
RobertM's Avatar
thank you for your comments!
Old Apr 15, 2005 | 04:51 AM
flat6's Avatar
flat6 is infamous around these parts
Ok let's say you are stupid and use a cloth with lint. How the hell do you get it off?
Not saying I have or anything.........
PS Lint Brush doesnt work
Not that I tried or anything.............
Thanks.
Old Apr 15, 2005 | 06:48 AM
neil.schneider's Avatar
neil.schneider has a spectacular aura aboutneil.schneider has a spectacular aura about
Yea I have the Porsche kit and they want you to use their wash for the top too. I have some lint on mine and it is hard to get off. I will try the shop vac method and report how that works.
Old Apr 15, 2005 | 11:03 AM
tmy727's Avatar
tmy727 is infamous around these parts
For lints, I've used clear boxing tape. I get a piece about arms length... hold both ends so that they don't stick together (duh)... and dab the areas or even slowly (and lightly) gliding the tape on the canvas. Tape always seem to work well on clothing, so I figure what the heck...
Now I just spray with water and run my hand on it.
Old Apr 15, 2005 | 12:25 PM
djantlive's Avatar
Use a lint roller to clean up lint and dust on tops. Lint roller does not leave any adhesive and doesn't pull on the canvass.
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
Rockinc1
Sep 30, 2015 06:44 PM
zuman
Sep 3, 2015 08:27 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
