cost to replace coolant expansion tank
Old May 26, 2011 | 04:49 PM
marvelusmarvcus's Avatar
marvelusmarvcus is infamous around these parts
Finally found out that my expansion tank needs to be replaced. Was quoted between $1500-$2000 for the repair.
should it be that much?
Old May 26, 2011 | 05:43 PM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
Replacing the reservoir appears to be a reasonably easy DIY job, explained here for a Mk1 996: http://www.renntech.org/forums/tutor...on-a-my99-996/
The part itself, for a 99-01 996, is around $200: http://www.porscheoemparts.com/partl...layCatalogid=0
I imagine a Mk2 isn't too much different but I don't know that for sure.
So...given the above...I would say that no way in Hades is it a $1500-2000 job. 1/3 of that amount seems much more reasonable.
Good luck.
Last edited by 02TX996Cab; May 26, 2011 at 05:45 PM. Reason: Fixed misspellings and corrected bad grammar
Old May 27, 2011 | 10:41 AM
CS Jeff's Avatar
CS Jeff is infamous around these parts
The Mk II requires the engine to be unbolted from the motor mounts and lowered w/ a jack to get the necessary clearance to remove. I did it in my driveway. Definitely not worth $1500. The MK I is easier, but they are both DIYs. It's much easier than it sounds, once you've done one you can do the next one in half the time. I tried to get it out without lowering the engine and it just wouldn't clear. If I had lowered the engine firat, I would have gotten it out in about a half hour. Reinstalled in a little more than that.
Old May 29, 2011 | 12:34 PM
996tofast4911's Avatar
996tofast4911 is infamous around these parts
YouTube 996 expansion tank n there is a dys video about it. I did it myself about a month ago for 300 bux plus antifreeze cost... Super easy
PelicanParts.com
Aug 21, 2015 04:23 PM
PelicanParts.com
Aug 21, 2015 01:37 PM
PelicanParts.com
Audi Vendor Classifieds
Aug 21, 2015 01:28 PM
PelicanParts.com
Aug 20, 2015 04:01 PM
PelicanParts.com
BMW Vendor Classifieds
Aug 20, 2015 03:22 PM
