Flickering headlight - help!
Old Aug 7, 2011 | 09:43 AM
bjarne996's Avatar
bjarne996 is infamous around these parts
The right hand headlight on my 1998 C2 is flickering constantly. Both high and low beams are flickering.
Since I have aftermarket HID kits installed and the lights do NOT flicker with the standard Halogen bulbs installed I suspected the aftermarket HID kits. However, after swapping the left and right hand side HID kits, the right hand side is still flickering!
I've searched the forum and others have indicated that the light switch or the ignition switch might be the problems if BOTH sides are flickering.
Could one of these switches still be the causing these problems?
Thanks,
Bjarne
Old Aug 7, 2011 | 11:27 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
I've got aftermarket HIDs from sponsor on here....had similar symptoms...It had been driving me nuts for a few months thinking it was the HIDs...
I got new headlight switch..the one behind the switch on the left....it solved mine
Mine would flicker....take a while to turn on...eventually wouldn't turn on
Old Aug 7, 2011 | 11:41 AM
bjarne996's Avatar
Did both your headlights flicker or just one?
Was replacing the headlight switch expensive?
Thanks Bjarne.
Old Aug 7, 2011 | 06:31 PM
geetee's Avatar
I believe my high beams were fine...just my low beam...started with one then both started flickering...light would eventually become intermittent I had to turn on off a few times
It's really easy to replace...I paid around 100 or so. I believe it was from suncoast
DYL 911
Oct 20, 2025 05:08 PM
adnanm3
Oct 25, 2016 08:38 AM
Perkman87
Nov 19, 2015 05:31 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
