996 engine failure
Old Aug 13, 2011 | 02:11 PM
BlackC2's Avatar
BlackC2 is infamous around these parts
996 engine failure
My Indy thinks some vandal put something my gas tank that caused my engine to fail. What could cause a piston to crack?
Old Aug 13, 2011 | 02:35 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
why would you think that..and besides...doesn't you gas door lock when you lock your car?
Old Aug 13, 2011 | 02:47 PM
BlackC2's Avatar
We have vandals targeting us and there appears to something spilled in there ( not gas).
Old Aug 13, 2011 | 03:53 PM
crazyed71's Avatar
crazyed71 is infamous around these parts
i have heard that sugar (not sure on the amount) would do that.... But like above... Did you have your gas lid open?
Old Aug 13, 2011 | 04:33 PM
BlackC2's Avatar
Not always locked in my gated community
Old Aug 13, 2011 | 05:23 PM
BlackC2's Avatar
Does anyone know for that sugar could cause a piston to break?
Old Aug 13, 2011 | 07:16 PM
CoolHand's Avatar
CoolHand is infamous around these parts
In a past issue of Panamera they talked about d chunked piston walls?
Old Aug 13, 2011 | 07:39 PM
wyovino's Avatar
wyovino is a jewel in the roughwyovino is a jewel in the roughwyovino is a jewel in the rough
If you can prove that it was vandalism, you're insurance will probably cover it.
Old Aug 13, 2011 | 07:52 PM
BlackC2's Avatar
I read that.
I'm trying to find out what in my gas tank could cause the piston or wall to fail.
Old Aug 13, 2011 | 08:08 PM
Richard996TURBO's Avatar
Richard996TURBO is infamous around these parts
Ouch get a sample of the fuel tested........ if its tampered claim on your insurance.
Old Aug 14, 2011 | 01:11 PM
BlackC2's Avatar
I usually fill my tank when it's about half empty, which may have caused this to happen over a few weeks.
Old Aug 14, 2011 | 01:38 PM
valmeida's Avatar
valmeida is infamous around these parts
That sucks and good luck a used or remg engine can be expensive.
Old Aug 15, 2011 | 08:10 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I thought mythbusters proved sugar did NOT do anything to modern cars.
I beleive flat6 inovations states the water pump can cause this issues by the impeller breaking down and causing hot spots.
Old Aug 16, 2011 | 06:09 PM
crazyed71's Avatar
I found something on an italian porsche forum... A mechanic suggested that sugar vaporizes in the chamber and with heat, it created a hard caramel like coating that would than be compressed over and over. Subsequently enough mass would be in the chamber, to crack a piston or line the cylinder heads.....
Dont know the science behind his story but it did sound possible..
Old Aug 16, 2011 | 06:20 PM
BlackC2's Avatar
Thanks for the help! I was told soda, orange juice and many liquids with a high enough sugar content can cause these engines to go POP!
