Please Help! Major concern with 2002 911 C4S
Old Sep 20, 2011 | 09:58 AM
strat10's Avatar
strat10 is infamous around these parts
If it is tied to your driving habits then you still need to find out what is wrong. I drive mine hard every day, and it never smokes. There is something not right here. It may be as bad as you thought, but you need to have it checked out.
Old Aug 12, 2013 | 11:13 AM
Volkers's Avatar
Volkers is just really niceVolkers is just really niceVolkers is just really niceVolkers is just really nice
I have a 2002 996 C4 and it will this the next morning on startup after spirited driving .
Now has 117k miles on it and still runs great 😄
Old Aug 12, 2013 | 06:59 PM
bmantdot's Avatar
bmantdot is infamous around these parts
I'm in Toronto. Just changed my oil from Mobil 1 0-40 to Motul 5-40. My engine sounds quieter and I just feel better after reading lots of good stuff about motul. Try a fresh oil change.
Old Aug 13, 2013 | 07:49 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
id check the oil level first, might be overfilled
Old Aug 13, 2013 | 06:17 PM
Volkers's Avatar
Oil level
Yes, oil level may be the issue.
I just had an oil change ( while having the ac evaporator changed...very expensive )
Today: no smoke on start - up.
If I drive aggressively , i am pretty sure I will have a puff of smoke the next day.
The oil level is near the top of the dip-stick.
Generally, if you do some track driving, they say you need to keep the oil level at mid dipstick level.
Boxer engine etc.
It just feels soooo gooood flooring that thing off and on :-D
Old Aug 14, 2013 | 05:41 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
this thread is 2 years old, i'm guessing he found the problem
maybe he could post what it was
Old Aug 14, 2013 | 05:20 PM
jacabean's Avatar
jacabean is infamous around these parts
let your car idle for a minute or two before shutdown after a hot drive . you will not get as much smoke the next day .
Old Aug 14, 2013 | 05:22 PM
Byprodriver's Avatar
Byprodriver is infamous around these parts
Try allowing the engine to idle for a full minute in a level parking spot before turning the engine off. This allows more of the oil to be pumped out of the heads & returned to the sump where it is less likely to get past the rings.
Old Aug 17, 2013 | 09:08 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Originally Posted by blown
Hmm....that sounds concerning. It's hard not to drive the car hard that's. Does anyone have the issue as me where it doesn't need much to hard driving to have smoke at start? Has anyone replaced the AOS and found it has resolved the issue?
Are you parking on a hill/inclined driveway? If so, turn it around and park the other direction and see if that helps - or park on a flat surface. I've seen that after parking on a hill tail down.
Old Aug 18, 2013 | 09:21 AM
Volkers's Avatar
Smile Blue Smoke
I park on the level.
The idling idea seems to work.
Incidentally, I had the same thing on my '89 911 Targa off and on.
When I use it driving normally on my work commute its not a problem .
2lflat4
Nov 18, 2019 05:05 PM
SharkyShark20
Sep 19, 2015 09:54 PM
Michael_s
Sep 11, 2015 08:03 PM
Phoenix604
Aug 19, 2015 10:39 PM
