Cab top removal question.
Old Sep 23, 2011 | 12:43 AM
the1sojourner's Avatar
the1sojourner is infamous around these parts
Hello Everyone,
I have a 996 cab with a hardtop and I decided that there is no reason for me to carry all the extra weight of the folded soft top. I figured that if I could pull it out of the car it may help handeling and maybe gas milage. Without getting into the merits of keeping the soft top or not, here is my issue:
In order to remove the soft top I had to put it in the "half way up" position. So predictably, once I got it out of the car and I got the hard top back on, the convertible roof dash warning light came on. I quickly realized this was because at the time I removed the roof it was not in the full open or full closed position. I have the 996 Porsche shop manual and it says to plug into a special computer or machine that I do not have.
Is there some way to "trick" the car into thinking the roof is all the way up, or all the way down to get the light on the dash to turn off?
Is there a way to short circuit the wires so that the computer thinks the top is at one of the end positions?
I already manually moved the rear cover and side flaps closed using the allen key provided behind the rear seats ... but the dash light is still on.
I hope all this makes sense and I very much appreciate any help you guys have.
Thank you!
Old Sep 23, 2011 | 01:07 AM
djantlive's Avatar
you removed the whole folding mechanism or just the fabric?
sounds like it's the whole mechanism. i don't think you can fool the system.
your best bet is to use the soft top instead of the hard top. hard top is pretty heavy and ugly.
Old Sep 23, 2011 | 01:09 AM
That is correct, I removed the entire mechanism. And the hardtop is heavy. Let's assume for argument sake that I do not have a hard top at all; rather, I just need to save the weight of the soft top for a race this weekend. I still have the problem of the dashboard waring light.
Old Sep 23, 2011 | 07:12 AM
WDC 911's Avatar
WDC 911 is infamous around these parts
How about this, if this indicator light doesn't cause any adverse effects to other safety systems then why not cover or disconnect the indicator light bulb or light harness?
Old Sep 23, 2011 | 09:12 AM
sempaipaul's Avatar
sempaipaul is infamous around these parts
Id love to see some pics of this...
Old Sep 23, 2011 | 11:25 AM
Great question. The only problem is that when I lock the car with the remote the security is disabled because it thinks the roof is not shut. Other than that this may be a solution.
Old Sep 23, 2011 | 11:27 AM
What exactly would you like to see pictures of? The car is to the left of my name.
Old Sep 23, 2011 | 11:34 AM
WDC 911's Avatar
He wants to see the gutted out area of the compartment.
Old Sep 23, 2011 | 11:38 AM
Ok, well it looks like I am going to have to take the hard top back off and mess around with it so I will snap some pics.
Old Sep 23, 2011 | 12:36 PM
WDC 911's Avatar
So you need to find the switch in the compartment that lets the car know the top is open or closed.
Old Sep 23, 2011 | 03:46 PM
Thanks everyone I figured it out. There are 3 on/off switches on the roof itself that signal the position of the hook and roof. There is also a switch above the windshield. Instead of trying to figure out which switch means what I just re-wired the soft top and hit the open/ close button until the dash light went out. Then the system thinks the roof is all the way down and you can pull the soft top back off and it will not trip the light.
Old Sep 24, 2011 | 08:30 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Ok, I have to ask this question. You live in San Diego and have a cab and your are taking off the convertible top and running a hardtop full time? Why? San Diego has the perfect weather for a cab. And if you did not want to be able to run with the top down why not buy a coupe, lighter, stiffer, etc.?
Just wondering.
Old Sep 24, 2011 | 08:12 PM
Just wondering.
Great question. I have had convertibles here in SD for years and I just needed a change for a little while. I might re-install the soft top later. I can still always take the hard top off and drive it with no top at all (although I am not sure how to close off the hole that where the top goes). Taking the soft top out is surprisingly easy. I did not buy a hardtop p-car originally because at the time I wanted a cab (and I still like having the option).
Old Sep 25, 2011 | 10:06 AM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
Your opening up a big can of worms. There are so many micro switches in this set up of the car. Everything works in series. If you screw up one of the series the top will never work right. I changed the pistons for the top in my car and it threw the whole series out of whack. Had to take it to the dealer to get a new computer for the top and $1500 later I was a bit pissed. I would just leave the top a lone and sell the car for a coupe.
Old Sep 25, 2011 | 11:47 AM
You are right about that. There are a few micro switches and they do all work in a series. I have the shop manual wiring diagram for the whole system. I am surprised the shop charged you so much because in the Porsche Shop Manual it says that if they get out of sync all you have to do is manually put the roof in one of the end positions and plug the car into their computer and "reset" it. Thanks for all the advice everyone, and please stop worrying. I have already removed it AND re-installed it without a problem. It is very easy.
adnanm3
Nov 22, 2023 02:43 AM
NIKAS
Aug 20, 2019 07:53 PM
Feelgood MD
Mar 24, 2016 09:35 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
