Pulling the battery
Old Feb 27, 2012 | 06:38 PM
flybye_'s Avatar
flybye_ is infamous around these parts
Pulling the battery
Time for a new battery it seems, before I disconnect the power do I need the radio code? I have the big nav unit in my 2004 996, not sure if there is a code
Thanks,
Old Feb 27, 2012 | 08:31 PM
rrrruben's Avatar
rrrruben is infamous around these parts
I do not have navi, but I would think you would need the radio code. If you have the original owner's manual package, the radio code card is tucked in the opening flap of the package. Other than the radio code, you will also need to reset your auto up-down window, sunroof, and memory seats if applicable. Good luck.
Old Feb 29, 2012 | 12:37 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
You should have the codes for your car. However, I suppose that you could use another charged battery and attach it to your terminals, then disconnect your battery and swap it out. Then connect the new battery before disconnecting the jumper battery. I would still get the codes for your car. You will certainly need it if/when your battery goes dead.
Old Feb 29, 2012 | 04:26 AM
flybye_'s Avatar
Do the pcm nav cars have codes? I wasl also thinking if I left my battery trickle charger on would it keep enough power in the system?
Old Feb 29, 2012 | 05:37 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
when I replaced my battery I did nothing...and never needed any codes
Old Feb 29, 2012 | 07:04 AM
Mine has the radio code and a nav. code.
Old Feb 29, 2012 | 10:33 AM
Slider's Avatar
Sooner or later you will need the code. My previous owner painted it on the bottom of the ashtray. +1 - there are two codes.
Old Feb 29, 2012 | 10:42 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Never needed a code on my 04. Battery had been replaced and disconnected many times.
BLKMGK
May 31, 2016 04:32 AM
saline
Sep 13, 2015 04:15 PM
lokmeup
Sep 9, 2015 09:24 PM
katyrow
Sep 7, 2015 10:17 AM
