Help: 2003 996 Stereo Question?
Old Jun 24, 2012 | 09:19 AM
911A4Mustang's Avatar
911A4Mustang is infamous around these parts
Question Help: 2003 996 Stereo Question?
I had my 911 in for service at my local Porsche dealer and had them take a look at my stereo as I thought it required a code (after a battery replacement it hadn't worked since). They informed me that I need a new radio receiver. My car is a 2003 Cabriolet with the CDR 23, Bose package and 6 Disc Changer in the front.
I would like to sell the car so I don't want to spend too much money (factory replacement cost is $900!) and I am not a car stereo guy. What are my options?
Thanks for any help!
Eric
Old Jun 24, 2012 | 10:15 AM
djantlive's Avatar
does the head unit power up and display any code request? i think that is what happens when you turn on the head unit after a power change.
if it's indeed faulty, you can get a used CDR 23 with a code on ebay, craigslist or on the forums. make sure it isn't the older CDR 220. before 2003, the stereo system uses different connectivity (not MOST).
Old Jun 24, 2012 | 10:23 AM
It intermittently powers up and displays PORSCHE on the screen and then powers down.
When you say 'code' what do you mean? I have seen a couple of units (CDR 23) on Ebay, in addition to the unit I need to have a code as well?
I love Porsche but they sure don't make things easy!
Old Jun 24, 2012 | 10:41 AM
Question like Columbo says: 1 more thing...
If I find a replacement CDR23 are they all the same and compatible with factory bose and CD changer?
Thanks!
Eric
Old Jun 24, 2012 | 01:53 PM
djantlive's Avatar
these may help you. looks like pulling the radio fuses resets the head unit
http://forums.rennlist.com/rennforum...up-screen.html
http://forums.rennlist.com/rennforum...turned-on.html
Old Jul 17, 2012 | 12:53 PM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
Check our Bencker Auto Sound North America.... They repair these units...
Old Jul 17, 2012 | 08:57 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
You can certainly put in an aftermarket system for less. That said, I have seen almost continuous availability of used Porsche stereo units. Check also with the dismantlers.
Old Jul 18, 2012 | 05:01 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
There are a half dozen or more on eBay right now, mostly. In the $150-$250 range. Make sure you get one that is compatible witht the Bose system.
Old Jul 18, 2012 | 09:31 AM
Neb's Avatar
Neb
Neb is infamous around these parts
I have one forsale, came off a 2003. I was told it did not require a code. Perfect working condition. Make me an offer
https://www.6speedonline.com/forums/...ecker-amp.html
Old Jul 18, 2012 | 09:50 AM
Gonzo911's Avatar
Gonzo911 is infamous around these parts
It sounds like you may not know your code. Try here http://www.renntech.org/forums/topic...-request-here/
Old Jul 19, 2012 | 07:20 AM
RF5BPilot's Avatar
RF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really niceRF5BPilot is just really nice
The CDR23 (model year 2003) is the first year that doesn't need a code.
They can be tempermental. The symptoms you're experiencing can sometimes be resolved by removing and replacing the fuse. Try reseating the connections. The head unit actually communicates with the amp. If a connection isn't perfect this can cause problems. Try disconnecting the cd changer and see if it will boot.
Fyi, you can avoid a lot of this if you will manually turn off the radio before you turn off the car.
2lflat4
Nov 18, 2019 05:05 PM
Enemy
Oct 24, 2015 04:14 PM
pshep138
Sep 1, 2015 09:45 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
