Temperature gauge is blinking red. Temp is at around 180-190 (normal temp)
Old Aug 28, 2012 | 09:00 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
That's not "hot". If you have proper coolant and oil levels, and your engine is not overheating then you should be fine driving it to the dealership. You'll likely find that the light is either a sending/sensing unit or faulty something. Have them make sure your engine compartment fan is working properly as that could be it as well.
Old Aug 28, 2012 | 09:03 AM
rrrruben's Avatar
rrrruben is infamous around these parts
+1
Old Sep 4, 2012 | 09:21 AM
trenddy996's Avatar
trenddy996 is infamous around these parts
It's on the pass side intake manifold towards the back of the car when you are looking in the engine. It sits in a rubber grommet. It looks like an outside air temp sensor.
Old Sep 6, 2012 | 01:17 AM
Black_911's Avatar
Black_911 has a spectacular aura aboutBlack_911 has a spectacular aura aboutBlack_911 has a spectacular aura about
Quick question guys....
This blinking issue happened after the repair was done. The repair was (cam actuator replacement) Which require them to drain some of the coolant.
Should this be covered by them or should I get charge to repair this?
We haven't diagnose it yet. I'm taking the car there this Friday for him to diagnose it first thing in the morning.
Old Sep 6, 2012 | 08:08 AM
Diagnose the problem first, then you can worry about who covers the bill. Probably you.
Old Sep 16, 2012 | 07:54 PM
Black_911's Avatar
Just bought a coolant lever sensor. I'll replace it soon. Does anyone have any link to DIY?
Old Sep 25, 2012 | 03:04 AM
Black_911's Avatar
Does anyone have a DIY link on how to remove the coolant level sensor removal?
Black_911's Avatar
I bought a coolant level sensor replacement.
BLKMGK
Sep 19, 2015 03:51 PM
jpik2003
Sep 10, 2015 05:18 PM
lokmeup
Sep 9, 2015 09:24 PM
katyrow
Sep 7, 2015 10:17 AM
