Headlight bulb swap problems
Old Sep 8, 2012 | 10:06 PM
rpm996c4's Avatar
rpm996c4 is infamous around these parts
I went to do a simple bulb swap and ended up with a big head ache.after swapping the bulbs I went to install the housing and it wouldn't make contact with the plug. Turns out the plug won't stay in place when pushing the housing in.i had to get my hand behind the plug via the wheel well to make a secure connection. How do I get the plug to stay in place? Also what are the high beam part numbers and other bulb numbers in the housing?
Old Sep 9, 2012 | 05:04 PM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
It's possible the stationary plug the unit plugs into may have a broken stem causing it to tilt backwards when you're installing the headlamp unit. Or, it could be you don't have the unit in its "grooves" so the plugs are not in alignment. As for the bulbs, in my 1999 C2 the bulbs are H7's for high, low, and fog lights. Hope this helps.
Old Sep 10, 2012 | 04:39 AM
jml3p's Avatar
jml3p is infamous around these parts
Hi
Have you locked the healamp in place? the reverse of what you had to do to remove the the headlamp.
Rgds
jl
PV=nRT.
Sep 9, 2022 06:06 PM
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
ppwchiang
Sep 1, 2015 11:22 PM
LiquidElephant
Aug 27, 2015 06:17 PM
metzkaro
Aug 24, 2015 02:59 PM
