Help car shut off while driving?
Old Sep 9, 2012 | 09:33 AM
911mike99's Avatar
911mike99 is infamous around these parts
My 99 996 shut off pulling into my development. I have a little bit less then 1/4 tank off gas. I tried to start it and runs for second & shuts down. Not sure if the low gas has something to do with it. Vapor lock maybe?
Old Sep 9, 2012 | 09:55 AM
Dennis C's Avatar
Fuel pump perhaps?
Old Sep 9, 2012 | 10:07 AM
911mike99's Avatar
Never had any warning. Just shut off down shifting from 4 to 3rd. It's been running great. Never any problems.
Old Sep 9, 2012 | 11:26 AM
911mike99's Avatar
When I turn key on I do hear the fuel pump working.
Old Sep 9, 2012 | 04:32 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Fuel pump or filter. You may be hearing your radiator fans. Either way it's not vapor lock.
Old Sep 9, 2012 | 05:47 PM
911mike99's Avatar
Some guy I was talking with said it might be my mass air flow sensor since I just installed a after market cold air intake a month ago.
Old Sep 9, 2012 | 06:56 PM
I doubt it's the MAF, wrong symptoms. Did you get a CEL? MAF problems usually begin with a CEL.
Old Sep 9, 2012 | 07:19 PM
TraderJoe's Avatar
TraderJoe is infamous around these parts
Bad gas? BP just had a recall. Odd for it to shut off without a code, then be able to start a nd run temporarily. Does sound like fuel pump...
Old Sep 9, 2012 | 07:30 PM
911mike99's Avatar
Shell 93 gas is what I use & I hear fuel pump running when I turn key on.
Old Sep 9, 2012 | 08:27 PM
TraderJoe's Avatar
Worth pulling the maf, spraying with cleaner ($6) to rule it out. Also check everything you touched while doing cai. Easy to leave something loose... Vacuum line etc. Is it running rough then dying, dying when you press the pedal?
Old Sep 9, 2012 | 10:08 PM
rrrruben's Avatar
rrrruben is infamous around these parts
As long as we are guessing, a failing cam/crank postion sensor could be the culprit. They tend to operate fine when cold. Then fail once they get to operating tempertures causing the engine to shut down. Aside from that thought, I would clean your MAF, and re-check the application of your new aftermarket CAI. Namely, airflow: vacuum hose, tubes, screen or lack of screen. Good luck.
Old Sep 10, 2012 | 04:15 AM
jml3p's Avatar
jml3p is infamous around these parts
What about taking the filler cap off and trying a start?
Old Sep 10, 2012 | 04:20 AM
911mike99's Avatar
What do you mean by filler cap?
Old Sep 10, 2012 | 04:22 AM
911mike99's Avatar
Is there a DIY on how to do cam shaft sensors?
Old Sep 10, 2012 | 04:36 AM
jml3p's Avatar
Sorry, the petrol filler cap
