hardened transmission mount
I've got DIY engine mounts and will probably tackle the tranny mount later. IMO, the tranny mount should be less stiff than engine mount to achieve a good performance to NVH ratio and thus use a lower durometer rated polyurethane. You can get these from places like Grainger or McMaster Carr.
Just saw a thread about this on the "other" forum. It's a transmission mount insert for the 996 C2 and some other models, except you don't have to press out the OEM bushing. Looks good, I'll probably give it a shot.
http://function-first.com/products/e...s-mount-insert
You don't have to press the mount out. The mount housing is alum and can be tapped out without removing tranny.
There's 2 companies that sell new mounts with 2 different hardness. Very easy to install
Not sure about being able to "tap" it out. I worked in a race shop where we removed the OEM mounts on numerous occasions. It required the transmission out of the car and about 2000 pounds of pressure on a press.
And I only know of the Wevo mount as an aftermarket alternative. Well, now the Function-First mount insert, too. Maybe you're thinking of the GT3 style trans mount?
any detail on the DIY engine mounts I did search but find noting?
Here are some helpful hints when DIYing the transmission mount on your 996:
911 Carrera Transmission Mount Replacement
And if looking for transmission mounts, we offer the following, click here.
Mark/Pelican Parts
Mark/Pelican Parts
for anyone else looking here are 2 options, one stiffer then the other
http://stores.ebay.com/AWD-Motorspor...&_sid=37297334
I installed the FrictionFirst bushing today, it is a pain to do without the use of a lift, for me at least. On my initial drive I noticed more vibes on acceleration in conjunction with the growl of my Fisters. Not unpleasant but there non the less. It should be noted I also have the RSS engine mounts. Shifting seemed more positive, but I will have to do more testing. I will do a more through text drive tomorrow.
Matt
Matt
Standing by - thanks in advance for keeping us informed on your findings. My only reason for doing it would be improved shifting. My car shifts like a dream sometimes and then other times, it seems like I am working the gear box instead of it just dropping into gear. I am hoping that inconsistency can be cured with this fix.
Thanks,
Ray
Thanks,
Ray
