HID Kit and Ballasts inside the headlight
Old Nov 5, 2012 | 05:54 PM
zeeeeeee's Avatar
zeeeeeee is infamous around these parts
Has anyone here installed the HID kits in their cars and left the ballasts inside? Any problems with heating up and melting the wires.
TIA
Old Nov 5, 2012 | 06:51 PM
aemr1968's Avatar
aemr1968 is infamous around these parts
Me no issues of that kind
Old Nov 5, 2012 | 06:52 PM
zeeeeeee's Avatar
thanks
Old Nov 6, 2012 | 07:36 AM
alpine003's Avatar
That would keep heat in and shorten the lifespan of the ballast as well as introduce possible condensation in some situations I would think. Have you touched a ballast that's been on for awhile? If this was ok, Porsche(and other manufacturers ) would've also put it on the inside. I just think its a bad idea. My$.02
Old Nov 6, 2012 | 10:45 AM
Neb's Avatar
Neb
Neb is infamous around these parts
I have mine outside the headlight housing, just drill a small hole on back to run the wires. Then I double sided tape it to the fender.
Old Nov 7, 2012 | 07:52 AM
teoulennon's Avatar
teoulennon is infamous around these parts
I've had a vvme slim balast kit inside mine for 2 months now with no problems. I'm not interested in drilling any holes.
EDIT: I should add that I drive 12 hours - 6 hrs non-stop each way every weekend and no issues with heat or the like.
Old Nov 7, 2012 | 08:25 AM
alpine003's Avatar
2 months is not really a long term sample imo. Heat and enclosed space(for the most part) never mix. It just seems like general electrical common sense. Ask any EE or electronic tech and they'll say the same thing.
Just because you can do it doesn't mean you should...
Old Nov 7, 2012 | 08:45 AM
teoulennon's Avatar
Great point alpine, you're right about that. But you never know until you try!
I've had hid kits on every vehicle I've owned for the past 5 or 6 years and have never noticed any of my ballasts getting hot enough to do damage. I feel confident that it's fine. I'll keep you guys updated if I ever have issues.
Old Nov 8, 2012 | 03:24 PM
white99c2's Avatar
white99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of light
I installed the ballasts inside the headlight assembly and they both over heated and burnt out. Don't do it, install them on the outside of the rear covers.
Old Mar 26, 2014 | 12:15 PM
Luigi tos's Avatar
Luigi tos is infamous around these parts
Ballasts in original casing
Hi I'm a newbie going to covert my 997 to hid this weekend after looking into it gonna put ballasts into original casing researched it and factory spec are also in the original case hence that's why there is so much space in it if you order a car with Xeon that's where they are same design as non factory spec Xeon so don't think there should be an issue
Old Mar 26, 2014 | 10:05 PM
Sameerl99's Avatar
Sameerl99 is infamous around these parts
What kind of kits do u guys have. Also does it have a a relay.
cadman
Nov 13, 2025 08:57 AM
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
The Oss
Aug 24, 2015 08:19 PM
PelicanParts.com
Aug 21, 2015 04:23 PM
