Front seat disassembly
Old Jan 23, 2013 | 03:38 PM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
I need a little help. How do you removed the backrests on the front seats? I'm talking about the back that pivots forward when you lift the levers on the headrest.
Reason I ask, I recently purchased a used set of front seats but I only need the backrest to the drivers seat. I've noticed what appears to be E12 torx bolts on either side of the seats. Do these have to be removed for the entire backrest to lift off? Will a 10mm socket work or will I need to purchase an E12 torx socket? Thanks for any help you can give.
I looked thru previous threads in this forum but nothing was availabe.
Old Jan 23, 2013 | 03:45 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Bolts on seats are on there tight, don't use the wrong socket.
I had to stand on a breaker bar when adjusting GT3 seats bolts.
Old Jan 23, 2013 | 07:15 PM
Pors-Vette's Avatar
Thanks, I've been looking at the seats for the past 2 hrs and can't figure out how the backs are removed. Those bolts, with what looks like male torx heads, are weird. There are 6 "teeth/gears" spaced on it but there is an empty space where another "tooth/gear" should be. Just can't figure it out. Things like this make working on the Z06 a lot easier.
Old Jan 24, 2013 | 01:30 PM
Pors-Vette's Avatar
Surely someone has to have knowledge of how to take the seat back off.
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
MurderedTurbo
Aug 28, 2015 09:06 AM
