LED Turnsignals hyperblinking when AC or Headlights are turned on...?
Old Mar 15, 2013 | 09:32 AM
fullmetaljacket's Avatar
fullmetaljacket is infamous around these parts
Hi guys, iI have aftermarket projector headlights with LEDs and also aftermarket LED tailights. My right turn signal lights hyperblink when i turn on my AC or Headlights. Strange! When the AC and HLs are off they blink normally. Any of you experienced this? Any quick fix? Why is this happening? TIA guys!
Old Mar 15, 2013 | 12:05 PM
NIKAS's Avatar
NIKAS is infamous around these parts
Hyperblink is one of the hazards of LED overdose. Try replacement load resistors (these will get super hot) and/or LED flasher relay. Search the threads on this one. My Dectane hyperblink issue was resolved with a DIY $12 LED flasher relay, but now I have some other electrical gremlins that are drawing power somewhere. Worst case, you can isolate the problem by putting an amp meter on the terminal and pull fuses until you find the problem area. Good luck!
Old Mar 16, 2013 | 12:43 AM
Thanks. Will be doing some experiments then. Ill try the resistors first - probably replacing the rear right resistor with a higher value will do the trick. Its just strange that it only happens when you turn on the AC or HID headlights. And this didnt happen before as well. Strange. Maybe thats what we get for messing around with the OEs :-)
cadman
Nov 13, 2025 08:57 AM
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
OllyTTS
Aug 30, 2015 03:09 PM
