HELP 2001 C4 will not start, no starter op
Old Sep 23, 2013 | 10:15 AM
r38johnson's Avatar
r38johnson is infamous around these parts
Exclamation HELP 2001 C4 will not start, no starter op
Sunday after church, the car wouldn't turn over! good battery, lights work, don't dim when I hit the start position. tried the second key no go.
where is the start relay and DME relay located.
Hint: When I went to start the car I found the car unlocked and windows down. Also on Saturday I found a gallon of water under the seat from a bad rain storm on Friday.
Old Sep 24, 2013 | 07:52 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Sounds like a starter/ignition switch. Common failure, simple solution - replace it.
Old Sep 24, 2013 | 08:26 PM
r38johnson's Avatar
no start
Originally Posted by denversteve
Sounds like a starter switch. Common failure, simple solution - replace it.
thanks, will jump the switch, tomorrow.
Old Sep 24, 2013 | 08:38 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
Probably the Ignition Switch. Common problem.
Old Sep 25, 2013 | 01:53 PM
fpb111's Avatar
fpb111 is infamous around these parts
Sounds like you drowned your alarm brain. It lives under the seat. Pull it out, open it up and see if drying it out will resuscitate it.
Old Sep 25, 2013 | 03:08 PM
r38johnson's Avatar
will not start
your right I found the M535 module had moisture and some corrosion, placed it in rice for 24 hours then I will use some PCB cleaner and pray that works
Old Oct 16, 2013 | 03:52 AM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
http://www.ebay.com/itm/2003-Porsche...098b2b&vxp=mtr There is a used one for sale here if all fails.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
ModBargains
Oct 13, 2015 03:45 PM
yumaverick
Sep 2, 2015 03:48 PM
