Shifter does not always engage reverse gear
Old Sep 26, 2013 | 01:42 AM
faandba's Avatar
faandba is infamous around these parts
Lately when I try to go in reverse the shifter does not engage reverse but if I try a few time it engages. All the other gears have no problem.
Old Sep 26, 2013 | 06:20 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Before you put it in reverse, try double clutching, sounds like a sinc problem.
Are the other gears notchy? If so your motor mounts could be bad.
Old Sep 26, 2013 | 08:36 AM
faandba's Avatar
No the other gears are good. I thought maybe it is the gear box so I figured I can upgrade to a 997 shifter and hopefully that would resolve my problem so I bought one and replaced it but still having the problem. I played with linkage adjustment which seem to help some time but can't get it reliable.
Old Sep 26, 2013 | 05:27 PM
alpine003's Avatar
You could have a leaky clutch slave cylinder and/or air in the line. Common to have to pump the clutch before reverse will engage smoothly.
Look at your slave cylinder to see if you see any leaks visually and go from there.
Old Sep 26, 2013 | 08:40 PM
blackbull's Avatar
blackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond repute
Gear synchros!!??
Old Sep 26, 2013 | 08:52 PM
alpine003's Avatar
Originally Posted by blackbull
Gear synchros!!??
This is reverse gear we're talking about...
Old Sep 27, 2013 | 09:53 AM
faandba's Avatar
I finally took it in to a local mechanic and the problem was the blue transmission wire linkage at the transmission side under the car was loose. He adjusted it and now it works perfectly.
Old Sep 27, 2013 | 02:27 PM
alpine003's Avatar
glad it was a cheap and straight forward fix.
Old Sep 27, 2013 | 03:15 PM
faandba's Avatar
I know, first I though it was the shifter so I replaced it with a 997 shifter but that was't it. At least I got an upgraded shifter out of it.
Old Oct 16, 2013 | 03:23 AM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
is yours a manual or auto transmission car?
Kai@ELITEMS
996 Turbo Vendor Classifieds
Nov 25, 2015 06:44 AM
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
Kai@ELITEMS
996 Vendor Classifieds
Nov 25, 2015 06:32 AM
Kai@ELITEMS
997 Vendor Classifieds
