Need Radio Help Please
Old Oct 4, 2013 | 11:43 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Well, went home at lunch, turned the radio off then the AC (I like everything in the off position when the car is not running) then about 15 minutes later went back to leave turned the car on then turned the AC on and then the radio, but wait, no sound Power is going to the radio as it works, shows the station changes from AM to FM to Cd etc..but no sound, nothing. Tried turning it off and on, shut the car down, then back on and still no sound. What could have happened?
Like I say the radio is on just no sound.
I have the Bose sound system.
Old Oct 4, 2013 | 12:30 PM
ECS Tuning - Porsche's Avatar
You can try to unplug the amp (in the trunk) and leave it for a few minutes, then plug it back in. Sometimes this "reset" brings it back (for a while at least). Otherwise, it's usually time for a new amp.
Old Oct 4, 2013 | 01:01 PM
FLA996TT's Avatar
Thanks, can you give me an idea of where the amp is? All I see is the CD unit.
Thanks, Jim
Old Oct 4, 2013 | 01:27 PM
If I remember correctly, it should be located on the back left side of the firewall inside the frunk of a C4S.
Old Oct 4, 2013 | 04:06 PM
USNCPO's Avatar
USNCPO is infamous around these partsUSNCPO is infamous around these parts
The amp should be under the floor of the trunk. In the spare tire well.
Old Oct 4, 2013 | 05:08 PM
invius's Avatar
invius is infamous around these parts
I'm thinking no, but may also check ignition switch? Make sure the key is turned all the way to the left. The electronics can get weird when the ignition switch is on it's way out. So start the car, and then manually turn the key to the right gently until you feel resistance. If suddenly your stereo is working perfectly again, it's the ignition switch. But in this case, it does sound like it is probably the amp.
Thanks,
DS
Old Oct 7, 2013 | 05:59 AM
FLA996TT's Avatar
Well, when I went out to leave work, it worked! And it worked all weekend. So I'll have to wait and see what happens next.
Old Oct 9, 2013 | 02:00 AM
Da4s's Avatar
Da4s is infamous around these parts
It may be time to get the amp fixed or replaced. I have the Bose system in my 02 4S and recently sent it to a company to get refurbished. The sound quality is better now than it has been for years.
Old Oct 9, 2013 | 05:57 AM
FLA996TT's Avatar
Nice, where did you send it?
Old Oct 10, 2013 | 09:17 AM
Da4s's Avatar
I will look up the address and company info and post it for you tonight. Fast turnaround and very happy with the result.
Old Oct 10, 2013 | 09:24 PM
Da4s's Avatar
I have the Becker CR-220 and sent my amp and head unit to Becker in NJ for refurb. My head unit had been problematic since it was new, so I took care of both at the same time. Hopefully your only problem is with the amp. As mentioned above, you can find the amp in the trunk. You will see the air vents/slots where the amp is located.
It cost $225 for the amp refurb.
Becker Autosound, LLC / 101 US HWY 46 W 2nd Floor / Saddle Brook, NJ 07663
http://www.beckerautosound.com/
Old Oct 10, 2013 | 09:37 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
The same thing happened to me a few weeks ago. It has never happened before, and hasn't happened since (though I haven't driven the car much). I can't remember whether the problem started when I started the car up for the first time, but I don't think so. I'm pretty sure I was running errands and stopped at a few places and at one of them the problem started. I also can't remember if the radio was off when I got in and started the car and then turned it on and had no sound, or whether it was already on when I started the car but didn't have any sound. I think it went away when I got home and just tuned the car off and back on and it was working.
I also have the Bose system btw, plus nav and the 6 disc changer. Good luck with it!
Old Oct 11, 2013 | 06:07 AM
FLA996TT's Avatar
For now I'll put this on hold as it's been working perfectly since then I'll play the ol' wait and see game.
vpr80
Mar 6, 2021 12:11 PM
7thsign
Dec 12, 2015 07:43 PM
alpha motoring
Oct 2, 2015 12:04 PM
Mz3bo
Oct 1, 2015 06:32 PM
TypeRx
Sep 28, 2015 08:24 PM
