Window glass stuck right at the bottom
Old Nov 11, 2013 | 02:12 AM
eyeain's Avatar
eyeain is infamous around these parts
Hi
I have a 2003 996 recently i tried to jump start my car because of the dead battery.While i hooked it to battery charger and tried to start both windows dropped but motor did not turn over.I put a new battery the car started straight away,the right glass went up by pulling the door switch but left stays down and whe i use the door switch there is only a clicking sound but no movement of the glass! ..... any ideas
Old Nov 11, 2013 | 04:46 AM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
Make sure before you do any checking, that the battery is fully charged before attempting anything further. If still the same, it might be time to take the inside of the door off and check the window and motor workings from that view. Is something catching preventing the window from moving? Has the window come off the guide rail (if there is such a thing). Micro switches? Find where they are and test them. Good luck./
Old Nov 11, 2013 | 12:22 PM
eyeain's Avatar
Thanks I will check and report.
Old Nov 22, 2013 | 11:16 PM
eyeain's Avatar
Took inside door off disconnected electric connection to motor from the car and hooked it to a separate battery window moves up down.I left it in up position and as soon as i put the normal connections back the glass rolls down and than wont go up.Any suggestions? Thanks
Old Nov 23, 2013 | 03:40 AM
is that with the spare fully charged battery? If so try it again with your own fully charged battery. If it is still the same, then I think it has to be a micro switch at fault. Now it becomes a whole different kettle of fish as I believe that there are 7 micro switches inside the 996 door. If this were my car, I would take it to a Porsche dealer and let them run their special diagnosis OBD2 tester on it to find the faulty micro switch. I would buy the switch and replace it myself. You may need to do that or have them replace it for you.
ExSF
Bentley
Apr 9, 2017 05:28 AM
Axxlrod
Oct 26, 2015 11:54 AM
BLKMGK
Sep 19, 2015 03:51 PM
All Pro Chris
New Member Introductions
Sep 17, 2015 08:21 AM
barncobob
Sep 12, 2015 09:24 AM
