How often should the Transmission Fluid be flushed.
Old Aug 25, 2005 | 07:11 PM
lceniza's Avatar
lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !
...on a 996 manual? This was recommended by a friend. Since I'm getting the 60k service done, should I just get this out of the way also?
TIA for everyone's input.
Old Aug 25, 2005 | 07:41 PM
Orient Express's Avatar
Orient Express is infamous around these parts
There is no service interval on the transmission oil or fluid in the case of an automatic.
However, it is probably prudent to change these fluids every 100-120K miles. If you track your car or otherwise use it in what is called a "severe duty cycle", then 60K is warranted, but if you do not race, or use the car for daily slow stop & go driving, then don't worry about it.
Old Aug 26, 2005 | 10:33 AM
lceniza's Avatar
The maintenance manual has it listed to be done at 90k...so I'll wait to do it then.
jaehoppa
Oct 22, 2015 09:17 PM
the5
Oct 14, 2015 06:46 AM
MrMiggy
Sep 14, 2015 02:18 PM
