Installing side skirts on 2001, C2 need advice
Old Apr 24, 2014 | 12:46 PM
nanoc15's Avatar
nanoc15 is infamous around these parts
So - just purchased GT3 mk1 side skirts. Just fitted them today and there is a gap rear of the panel. Just wondering if i should use polymer paste to fasten or ?
Also, does anyone have the part number for the clip set ?
Thanks in advance, Dadi
Old Apr 24, 2014 | 06:02 PM
alpine003's Avatar
If you're not using the metal clip rails, you can use 3m auto body tape to achieve the same thing.
Mine came with the metal clip rails but decided not to use them.
Old Apr 25, 2014 | 11:44 AM
nanoc15's Avatar
Hi Alpine 003 and thanks for the reply. Ok, i guess you are talking about the sides not underneath. Do you have any pics of the setup, etc. ? Im wondering about the underneath setup . . . .
Old Apr 25, 2014 | 12:36 PM
silverfizz's Avatar
silverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud of
Hi,
Are the skirts OEM?
The partnumber for the kit you are looking for is 000 044 000 37
Here are som pics from when I mounted mine.
If you need any more help, let me know.
ID:	365735   Click image for larger version
ID:	365736   Click image for larger version
ID:	365737   Click image for larger version
Old Apr 25, 2014 | 02:08 PM
nanoc15's Avatar
Hi silverfizz and thanks for the pics.
Unfortunately the skirt are not OEM but very nicely crafted. But i should be able to use the clips on that ?
Old Apr 25, 2014 | 02:12 PM
silverfizz's Avatar
Yeah, that shouldnt be a problem. Do you have the holes, shown in pic number one? Otherwise just drill some holes, and screw them in
Old Apr 25, 2014 | 02:13 PM
nanoc15's Avatar
Here are some pics - not sure if you see it but i trial fitted the skirt and there is this small gap on rear.
ID:	365801   Click image for larger version
Old Apr 25, 2014 | 02:19 PM
silverfizz's Avatar
Now I c what you mean. Well use some 3M tape as shown on pic number 3. That should solve the problem!
Old Apr 25, 2014 | 02:46 PM
nanoc15's Avatar
Ok that sounds good. Any suggested shopping place for the clips ?
Old Apr 25, 2014 | 02:54 PM
silverfizz's Avatar
If you just want the clips, I would go to the local porsche dealer, that is where I got mine from, dont Think they cost so much
Old Apr 27, 2014 | 03:22 AM
nanoc15's Avatar
Ok, ill check that out tomorrow - thanks
Old Apr 27, 2014 | 12:13 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
My advice would be to find a great body shop (everyone should have one) to do a professional install OR return them (which you can't do once you've don any DIY work to it). The way it is, I would never put it on my car. It either hasn't been properly adjusted or manufactured.
Old Apr 27, 2014 | 01:09 PM
nanoc15's Avatar
Hi denversteve, thanks for the advice. I know what you mean and i do respect that.
I love doing some work on my 911. I previously updated the stereo system to the ipad mini install, yellow brake calipers, tinted windows, water pump, carbon wrap etc. so im pretty excited about doing the side skirts to be honest.
I have the time to do it and with the right work and fitment i think it will look great. Anyway will post some pics if i get the clips from the dealer
Old Apr 27, 2014 | 04:51 PM
You are very correct. With the proper fit/trimming it should be fine. You'll probably have to reduce the high (front) half to allow the rear half to sit flush. I wouldn't use any type of filler.
Old Apr 29, 2014 | 03:08 AM
gurukid's Avatar
gurukid is infamous around these parts
nanoc, I have the exact same issue, perhaps we bought from the same company? Either way, I'm also working on a solution, I'll post back if I find anything out....
