LED Tails...
Old Jul 11, 2014 | 03:30 PM
996_911C2_Dhru's Avatar
996_911C2_Dhru is infamous around these parts
LED Tails...
Well I held off as long as I could and finally caved on a set of these.
Has anyone installed an OEM bright Amber LED front signal bulb? If so can you point me in the direction.
Old Jul 11, 2014 | 04:15 PM
BTERRY1's Avatar
BTERRY1 is infamous around these parts
very nice, what brand did you end up going with?
Old Jul 11, 2014 | 04:42 PM
Thanks. These are the Depo/Dectane LEDs that resemble the 997.2 lights. I used a Transfer Filter on the photo to see how they might looked if I smoked them.
Old Jul 11, 2014 | 05:00 PM
BTERRY1's Avatar
excellent. definitely on my wish list
Old Jul 11, 2014 | 05:43 PM
MkC2S's Avatar
very nice.
the clear of the turn signal would look better on light color cars than smoke..IMO...I got the smoke version b/c I want it to blends in with the rest of the car
Old Jul 14, 2014 | 08:12 AM
ECS Tuning - Porsche's Avatar
Nice work. Those look really good! Post a few pictures outside without a filter if you would.
Old Jul 15, 2014 | 12:32 PM
bernard.barbour's Avatar
bernard.barbour is infamous around these partsbernard.barbour is infamous around these parts
Did you or could you/is there a thread on installation. They look great. Thanks
Old Jul 16, 2014 | 12:29 PM
Some photos with no filter are below!
If you have a wide body car (C4S), they won't fit for you unfortunately.
As for install it is pretty simple.
1. Pop engine hatch/cover
2. Remove 10mm bolt holding OEM lens in
3. Disconnect the wire connector
4. Clean the inside area where the old light sat (might as well)
5. Remove resistor from LED lamp (gently pry it off it is two-sided taped on) and remote mount to back of opening as shown in picture below with two-sided tape. This is to move the heat source away from the LED light
6. Reconnect wiring harness to LED light (optional - zip tie to secure it)
7. Slide LED unit in and re-tighten the bolt with a lock washer. I just snugged it as I didn't want to break anything
You will note that I used a lock washer and zip tied the connector during my install. This is out of paranoia as I have heard of a few members actually losing their LED lens. The lock washer prevents the bolt from coming loose... and if it were to come loose the zip tie holds the connector tight until I can address the missing bolt. If neither were done that lens would meet the road. The insurance is just too cheap to not do it
Old Jul 16, 2014 | 06:16 PM
Boooo I have a C4S, lol. Thanks for the update, it sure looks great.
Old Jul 18, 2014 | 02:09 AM
silverfizz's Avatar
silverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud ofsilverfizz has much to be proud of
That is one Beautiful ***!!!
Old Jul 18, 2014 | 11:22 AM
jriggs's Avatar
jriggs is infamous around these parts
Looks killer! When you get a chance can you snap a pic of them out in the sun?
Old Jul 20, 2014 | 09:05 AM
Ruagatr's Avatar
Ruagatr is infamous around these parts
led tails
Where did you buy them?
Charles
Old Jul 21, 2014 | 10:38 AM
Thanks guy - Will take some shots in sunlight very soon. I bought them from a 6speedmember B8_RDC (great guy) who went with a widebody and had no use for them. I believe you can get them on ebay for around $650-700.
Honestly I think they are worth it. The back of these cars need some updates in my opinion Plus if you ever sell your car, you can recoup most of your investment by selling these back to another member at minimal loss. They flash about as bright as the OEM lights which is not common among aftermarket LED tail lights.
Old Jul 22, 2014 | 07:08 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Weld them in!
Old Aug 13, 2014 | 11:50 AM
33jacket's Avatar
33jacket is infamous around these parts
sweet so $ though...wish were 300 not 700
