Brakes and Rotors for 2003 996
Old Jul 30, 2014 | 12:52 AM
maitrey17's Avatar
maitrey17 is infamous around these parts
Question Brakes and Rotors for 2003 996
Hello Team,
I'm looking to replace my brakes and rotors myself on 2003 996. Its my daily commute car and I also take it on track, few times a year. Which brakes/rotors would you recommend?
Cheers,
Maitrey
Old Jul 30, 2014 | 05:50 AM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
Rotors -- Sebro (OEM supplier IIRC)
Pads -- stock or Hawk HPS (what I'm using and am happy with them)
Some hard-core track enthusiasts I know switch pads to a more track-specific compound for track days, then back to street pads for around town.
Old Jul 30, 2014 | 06:52 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
The HPS is a good pad, you can also use the ceramic with the iron disks.
Old Jul 30, 2014 | 08:47 AM
ECS Tuning - Porsche's Avatar
We offer a few different kits that include everything you need to do the job. For more information Click Here.
Performance kit includes the following items:
  • Sebro Sport slotted front & rear rotors
  • Hawk HPS front & rear pads
  • URO brake pad wear sensors
  • ECS stainless steel rotor set screws
Old Jul 30, 2014 | 05:18 PM
MiamiC70's Avatar
MiamiC70 is infamous around these parts
I'm in same boat. How much for OEM discs and pads?
Old Jul 31, 2014 | 04:10 AM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
Try Pelican Parts when you see what you need or PartsGeek.
Old Jul 31, 2014 | 05:53 AM
FLA996TT's Avatar
The package from ECS is a nice one, all 4 rotors, pads, sensors, lube.
http://www.ecstuning.com/Porsche-200...Kit/ES2598676/
Old Jul 31, 2014 | 11:12 AM
maitrey17's Avatar
- I track 2 to 4 days per year. Otherwise its my daily commute car. Will the package with Mintex pads sufficient for me or should I go with Hawk HPS package?
- Is Mintex pads ceramic? How is the wear with slotted rotors?
- How are Hawk PC pads?
- Among the following pads, which ones rate highest (racing pads) lowest (street driving): Hawk PC, Hawk HPS, Mintex, Pagid RS, Poterfield.
Maitrey
Old Jul 31, 2014 | 12:41 PM
FLA996TT's Avatar
I would address your questions to ESC, they are a wealth of knowledge and help.
I will say this; you should not use racing pads for everyday street use, racing pads need a lot of heat to work properly and normal driving won't get them there. This is why people change out the pads on track day.
If it were me ask them which pad has lowest amount of metal.
Maitrey
Old Jul 31, 2014 | 01:53 PM
Maitrey
To answer the questions in order:
  • I would go with the Hawk HPS package. HPS stands for High Performance Street. They are intended for vehicles that primarily see street use, but they do perform better on the track than OE pads.
  • The Mintex pads are not ceramic. They are an organic compound comparable to the OE pads. Slotted rotors will produce very similar wear to the stock cross-drilled rotors.
  • The Hawk Performance Ceramic pads are not as aggressive as the HPS pads. The ceramic compound reduces dust and noise, with a slight increase in braking performance over stock, but not as much bite as the HPS pads.
  • In order of performance: Pagid RS, Hawk HPS, Hawk PC, Mintex. I have no experience with Porterfield pads.
Hope this helps and let us know if you have any other questions or concerns.
Old Aug 13, 2014 | 12:14 PM
33jacket's Avatar
33jacket is infamous around these parts
so hawk PC is still a stock upgrad on a 996??? I didn't know that. May be a good balance to reduce dust.
why slotted vs stock cross drilled any preference?
Old Aug 14, 2014 | 12:52 PM
Yes the Hawk Performance pads would be a stock upgrade. The slotted rotors tend to last longer for the track guys, as they don't get as much cracking compared to the cross drilled.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
Enemy
Oct 24, 2015 04:14 PM
awchristler
Bentley
Aug 24, 2015 03:53 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
