Front brake lockup on 4S
Old Aug 13, 2014 | 05:05 PM
jjmullen's Avatar
jjmullen is infamous around these parts
Has anyone had this issue? and how did you resolve?
I have a 996 C4S, just doing a usual drive and turning left, the right front wheel seems like it wanted to lock up or did. I wasn't pushing the car hard at all. Could have been doing 20mph quicker around the turn. I haven't had this issue at all before. No lights came on, on the dash.
Doing a little old research I did see some possible things it could be. I did just take off my track tires/wheels combo and put my street tires/wheels combo on. The rears of my street tires are new but not the fronts. Although the fronts are in like new condition. The rears are not the same exact tire, but the same size.
Any thoughts? Suggestions? Thanks in advance!
Old Aug 13, 2014 | 05:46 PM
Dennis C's Avatar
Mixing tire brands can cause many issues, and something like this could be one of them. Even though they are the same size, there are differences between manufacturers.
I've heard of bad wheel speed sensors causing similar issues.
Old Aug 13, 2014 | 06:04 PM
jjmullen's Avatar
Thanks Dennis. I have read this tire change might be the challenge. Hope not. I'm going to have my tire guys check it out soon. Cheers.
Old Aug 14, 2014 | 09:10 AM
Zookie's Avatar
what Wheel and Tires Size are you running?
Old Aug 14, 2014 | 11:37 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Different tire could be the problem, but it could have been the PSM overreacting, on the C4S it feels different because of the all wheel drive system because it moves power around with the transaxle not just the brakes as is on a C2.
Old Aug 14, 2014 | 02:08 PM
jjmullen's Avatar
Fronts 225/35ZR19 - Toyo Proxes
Rear 315/25/ZR19 - Nitto Invo (Toyo backordered with no plan of when avail, so I went with these tires instead of the match to the front)
Old Aug 15, 2014 | 10:05 AM
Zookie's Avatar
mmmm Weird! because that is 100% Correct size!!
So its not your Wheel and Tire Set-Up
Old Aug 15, 2014 | 06:18 PM
peteb3's Avatar
peteb3 is infamous around these parts
Check air pressure in fronts
Are they worn?
Old Aug 27, 2014 | 10:48 PM
911C4S's Avatar
911C4S has a spectacular aura about911C4S has a spectacular aura about911C4S has a spectacular aura about
Tire pressure/new tires
I had the same issue when I bought two front new tires. This exact thing happened to me after buying new tires. I was told the PSM was engaging which only happened on off ramps. Not really pushing it at all. I turned off the PSM for about a month and no issues. After a month I turned the PSM on and it never has happened since. I recently got new shoes and tires for my ride (19) and everything is perfect. Rusnak said when you switch out just 2 tires this might happen with the 4S. Hope that helps.
Old Aug 29, 2014 | 12:06 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Not true really. It isn't just size. It's grip and composition and more importantly how the car senses the difference. Never mix tires or in other words - ALWAYS use the same make AND model because of differences. If you aren't sure, you can call any tire engineer and they will confirm for you.
Either way, driving a car with the front end grabbing is not safe. The way to resolve it is to have it checked at your dealer and fixed as necessary.
Old Sep 9, 2014 | 06:59 PM
jjmullen's Avatar
Thanks for all the feedback. I haven't had a chance to drive it much lately so I haven't seen if its still happening. From what I have read, I think the 2 different tire compounds is probably the reason behind it. Guess new fronts is in order! Thanks again!!
Old Sep 11, 2014 | 05:27 PM
porschemama's Avatar
porschemama is infamous around these partsporschemama is infamous around these parts
Sorry to high jack the thread and the delay (haven't checked in since school started)..... Dennis C, a new turbo? Congrats! Welcome to the turbo world! Are you loving it? It's a ridiculous car.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
The Oss
Aug 24, 2015 08:19 PM
