change master brake cylinder cause psm faulty light?
Old Dec 26, 2014 | 02:41 AM
pold9000's Avatar
pold9000 is infamous around these parts
i changed my master brake cylinder to a cylinder from a car without psm (have two 12mm sockets, the 996 psm has one 10mm front and 12mm rear) - i used a 10mm adaptor.
the brakes works fine - no comparsion like befor - but after the first start of the engine the abs/psm light appears in the dashboard.
i read in the forums that the secondary brake circuit has to be bleedet - i let this do the porsche dealer because my durametric cannot start the booster pump.
no result - after driving 1/2 day or sometimes only after 5min the psm/abs light appears.
now i have changed the maf sensor to an aftermarket product - the psm/abs light appears after one day!
in the workshop manuel there is an instruction to test the psm - i had an failure on pin 2 where is a voltage from about 5V instead of 0,3V - i can find no problem in the harness nor know where the cable connects in the main harness?
if the lights are off the abs/psm works fine - but if they on - the abs/psm is not working.
in durametric i have the fault pressure sensor 4460 - but this sould come often.
do you think psm recognices the other master brake cylinder? sometimes the light apears also if i dont have braked!
bye
wolfgang
Old Dec 28, 2014 | 03:14 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Wolfgang, at this moment I'd change the brake light switch located at brake pedal. If your new MC produces brake pressure (above some preset limit) before the switch makes contact, then the Pressure Sensor Fault (P4460) activates.
Another thing is that aftermarket MAF you're using. If it's a genuine Bosch there should be no problem. But if it is a chinese copy from evilbuy, the reason is there...also if you're using a KN (or similar) oiled aircleaner you're heading to trouble.
MfG,
Old Dec 28, 2014 | 05:45 AM
pold9000's Avatar
[QUOTE=pete95zhn;4262470]Wolfgang, at this moment I'd change the brake light switch located at brake pedal. If your new MC produces brake pressure (above some preset limit) before the switch makes contact, then the Pressure Sensor Fault (P4460) activates.
i will change it but i drove now 2 days without psm light in snow with many abs/psm working, perhaps there was some rest air in the secondary circuit.
the MAF dont worked fine i had some failer items in the dme, the original bosch works good - actual values tested with durametric
thank you
wolfgang
COBB Tuning
Jan 1, 2025 09:02 AM
alevine
Nov 4, 2015 10:05 AM
00aston
Aug 27, 2015 12:01 AM
oddjob142
Aug 24, 2015 05:49 PM
TrackOne
Aug 20, 2015 12:56 PM
