Transmission sensor and leak
Old Oct 6, 2015 | 08:50 PM
phils996's Avatar
phils996 is infamous around these parts
About 2 weeks ago, i notices a small oil spot under my 911. I wasn't sure if it was from my car or was already in the parking spot that i was in. I checked my oil and it was fine. I moved it a few feet and checked it a little while later and there was no spot. I've been keeping an eye on it and haven't noticed anything until a couple of days ago. I noticed a new spot on my garage floor. Looking under the car, i noticed something dripping from the plastic underlining. I wasn't sure what it was, so i checked the oil. it was fine. I got it on a lift today and found that it appears to be coming from a sensor on the front of the transmission (6 speed manual). When i removed the sensor, it was a little loose and doesn't have a washer on it. It is just threaded into the top of the transmission and is allowing tranny fluid to leak out. I haven't been able to find out what the sensor is, but i have a pic of it. can anyone tell me what this sensor is called and should it have a washer? it so, what kind of washer and how thick? Brass, nylon, rubber? This week, I am going to do a transmission fluid change, so can add a washer when i do it. I checked the tranny fluid and it was a little low but nothing alarming.
Thanks for any help that you can give me.
Phil
Old Oct 7, 2015 | 05:52 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Old Oct 7, 2015 | 07:42 AM
phils996's Avatar
Thanks for the info. I've seen that procedure, but couldn't seem to find out about the sensor. I finally figured it out though. its the reverse light switch. Everything i see online shows it without a washer, so I'm just going to put it back in and make sure it is tight and see what happens.
GrantRR
Jun 28, 2018 03:33 PM
saline
Oct 7, 2015 07:29 AM
k-lo
Cayenne 958
Sep 1, 2015 04:51 AM
hacellular
Aug 31, 2015 08:34 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
