Requesting 996 Battery Help
Old Oct 12, 2015 | 12:53 PM
Bobwombat's Avatar
Bobwombat is infamous around these parts
My 2002 996 battery finally died & I wonder if the Forum has any advice re: any specific battery recommendations. Which to buy, which not to? Or, is a battery a battery?
I'd like to support my long-time Indy but can certainly install a battery myself from Auto Zone or wherever if there are no specific requirements/brand, etc. Looks like my preferred "Optima" brand doesn't make one for this model.
Any help is greatly appreciated & thx in advance to the Forum!
Bob in AZ/USA
Old Oct 12, 2015 | 01:33 PM
bernard.barbour's Avatar
bernard.barbour is infamous around these partsbernard.barbour is infamous around these parts
Pep Boys has a Bosch battery, H6 premium 760cca 120min. Should be fine with this and the price is not bad.
Cheers
Old Oct 12, 2015 | 02:32 PM
Bobwombat's Avatar
Many thanks, Bernard! Was hoping for an alternative to WalMart.... Appreciate the help.
Old Oct 12, 2015 | 04:46 PM
Bobwombat's Avatar
Back to Bernard re: 996 Battery
Bernard, 1 more ? if I may.... Pep Boys has an AGM "H8" with some higher specs. The "H6 Premium" you noted is no longer listed. Would this still be ok?
Also, notes say "battery is vented outside the vehicle". Any guidance on this? I'm not home now to check if the battery box has a vent tube leading outside the front luggage compartment. Any thoughts?
Old Oct 12, 2015 | 04:48 PM
MkC2S's Avatar
I prefer Interstate H7 790cca from NTB. & it comes with the vent hole. it's not cheap tho.
Old Oct 12, 2015 | 05:50 PM
Bobwombat's Avatar
C2S: Thx to you & Bernard for the quick help today. I'll also check out the H7 & also educate myself about the venting requirement.
Btw, still looking for something cheap for this car; figured even a battery would be pricey. Out here in AZ they last about 2 years on average before they fry.
Thx again, guys; being a 996 Newb, I really appreciate the help!
Old Oct 13, 2015 | 05:45 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Die Hard Gold
Old Oct 15, 2015 | 12:25 AM
Socalsporty's Avatar
Socalsporty is infamous around these parts
Autozone has a gold battery that will fit with the vent on the top middle left. They even put it in for me (Chandler location) It was only $105 but that was about 2 years ago and it seems to me prices have gone up.
Old Oct 19, 2015 | 02:14 AM
west coast's Avatar
west coast is infamous around these parts
All Batteries (Porsche) have a small vent tube that you attach to the vent on the unit which takes anything from the Battery overboard.
Old Oct 20, 2015 | 09:45 AM
b2sc's Avatar
b2sc is infamous around these parts
I'd recommend an AGM type if you can swing it. I had a conventional battery and during track events the acid would leak down the vent hose and coat the underside of my chassis. It was a mess to clean up.
Old Oct 29, 2015 | 10:54 PM
Relegate's Avatar
Relegate is infamous around these parts
Do we like Optima batteries for 911's?
Old Oct 31, 2015 | 12:37 AM
dan_189's Avatar
dan_189 is infamous around these parts
Im a really big fan of Optima batteries in my previous car I had a yellow top and after 6 years its still going strong well worth it.
My understanding from what I have read is that they dont fit into 996s without some modification of the battery tray. This may have changed though. I'd like to get one as I only drive my 996 4-5 times a month and im constantly having to charge my standard bosch battery as it goes flat.
Old Nov 14, 2015 | 03:37 PM
Long Islander's Avatar
Long Islander has a spectacular aura aboutLong Islander has a spectacular aura about
H8 battery will fit but there is no nut for the bolt to thread into for that battery (just a hole for the bolt to go through). You need to be content with buying the right size nut and then holding it with one hand while you tighten the battery hold-down bolt with the other hand. Or, you can but a nut and epoxy it to the underside of the battery tray. If you get an H7 battery, you can just bolt it down onto the battery tray.
I strongly suggest any H7 AGM battery (Autozone, Bosch, Advance Auto, etc.). You will still need to use the vent tube for gas to escape.
Old Nov 15, 2015 | 04:52 PM
C4inDFW's Avatar
C4inDFW is infamous around these parts
I just went thru this same exercise last week, and called the couple of indies who have serviced my car. The all recommended the Interstate.
Based on my experience in TX, which is similar weather as yours, i would avoid the Die Hard Gold at all costs. Ive tried them a couple times and in multiple cars, and they leak so bad in hot weather that the cables go bad. Ive been left so many places that i swore never to buy another or even give another warrantied replacement battery another shot. Since switching to Interstate several yrs ago in all my cars, i will highly recommend them. Have never had any issues.
Old Nov 15, 2015 | 04:56 PM
C4inDFW's Avatar
Nearly forgot to mention the venting...i didnt ask what battery youre replacing. Theres a good chance you may already have it vented from the last replacement. Check your records to see if you were charged a venting kit last time.
Lastly, a lot of thes manufactureres have changed their free replacement warranties. Check before you buy.
