Fuel Gauge
Old Nov 4, 2015 | 11:13 AM
cWade's Avatar
cWade is infamous around these parts
Fuel Gauge
On my 1999 coupe the fuel gauge will drop rapidly from full to 1/2 tank and most of the time the low fuel light is on. After reaching 1/2 drove around for 2 days and it didn't move.
Anyone else have this issue? Possible sending unit problem?
Thank You and yes I did search
Old Nov 4, 2015 | 12:31 PM
UrsaMinor1's Avatar
UrsaMinor1 is infamous around these partsUrsaMinor1 is infamous around these parts
It's a strange one, sounds like a sensor problem to me. I'll be interested to see where this leads as I have a similar problem but in reverse. My fuel light comes on and not fill up right away, around 10-20 miles along I'll put £30 (25 litres) of fuel in but my gauge doesn't move and still shows I have x miles remaining on board computer. If I then put another 25 litres or so in my gauge leaps up to 3/4 full tank???
Sorry, not hijacking your thread but hope your problem sheds light on mine
Old Nov 4, 2015 | 01:39 PM
cWade's Avatar
Good to hear of your experience.
I've recently purchased this one and am learning it's little tricks and sorting it out.
Old Nov 8, 2015 | 10:21 AM
Macster's Avatar
Reads like the in tank level sensor is acting up. IIRC this is some kind of a float and the mechanism can be hanging up.
To check this possibility requires the fuel tank be opened up and the unit removed and examined.
Old Nov 8, 2015 | 10:26 AM
Macster's Avatar
A 4S (or Turbo) can do this. The fuel level system is a mix of mechanical and computer due to the saddle tank with two separate basins. At around half a tank the fuel level system in the tank becomes useless and the computer then takes over to calculate fuel level and range remaining based on how one is driving.
It is some fun to switch the on-board computer to miles remaining and drive in such a way, or try to drive in such a way, the miles remaining number increments instead of decrements.
Anyhow, if the tank level is real low if one doesn't add enough fuel to the tank to engage the mechanical fuel level measuring system the level can remain "unchanged" at the gage. When I fill up my Turbo's fuel tank I always fill it full. Barring the infrequent premature shut off -- which I seek to avoid by turning the gas pump nozzle almost upside down -- the fuel gage always reads full afterwards.
Old Nov 8, 2015 | 11:17 AM
cWade's Avatar
Interesting, when it reached 1/2 and remained there for a bit rather than worry I bought gas. Next time I'll let it go a little longer to see if it drops further. It was such a rapid drop to 1/2 then no noticeable change I became concerned.
Thank you for the replies.
Old Nov 9, 2015 | 10:01 AM
UrsaMinor1's Avatar
I also appreciate the info and advice, thanks
Old Nov 10, 2015 | 06:15 PM
dporto's Avatar
dporto is infamous around these parts
Mine ('99 C4) stops going down somewhere around 1/2 tank on the meter. I just use the trip odometer - reset at fill-up and re-fill somewhere around 200 miles (this gives me about a 100 mile buffer should I not be able to find gas).
Old Nov 10, 2015 | 08:35 PM
cWade's Avatar
Thank you for the reply and suggestion.
awchristler
Bentley
10
Jan 24, 2023 12:15 PM
ducaud
Dec 26, 2015 06:54 PM
ECS Tuning - VW
Oct 21, 2015 08:44 AM
ECS Tuning - VW
Oct 15, 2015 11:00 AM
tophebboy
Oct 14, 2015 06:59 AM
