Error code P1341 help
Old Feb 25, 2006 | 10:09 AM
ras1325's Avatar
ras1325 is infamous around these parts
Hi. I've got a 2000 911 and the check engine light was going on and off for a few weeks. It would go on for about 2 days, off for one and then repeat. After a few weeks of that it's stuck on now.
I had it checked out at the dealership, they said that it was giving the P1341 error code and explained to me that it means one of the camshaft actuators has gone bad and gave me a parts list and said it'd take 10-12 hours to fix. Instead of forking over the $1800 they said it'd cost, I took it to one of my guys and he had a look. He got the same error code, but said that the parts they said I need seemed fishy. He also said that the 10-12 hours seemed like they would need to pull the engine, but the service rep specifically asked the tech if that would need to be done and he said no.
996-105-051-58 Timing Ch 0 is the big part (~$650) and the rest are pretty much screws and rubber rings.
My guy can't figure out why they would tell me I needed a timing chain when they said it was an actuator gone bad. He called his buddy there and he said it doesn't make any sense either, but unfortunately he wasn't the mechanic who looked at it. He's going to speak with him again this weekend and try to figure out what's going on.
Has anyone else encountered a similar situation? Are there other possible culprits?
Thanks for the help.
longboarder
Sep 21, 2015 12:57 PM
intouch1
Sep 20, 2015 06:14 AM
nick-seattle
Sep 18, 2015 08:14 AM
