Battery Mod
Old Mar 11, 2006 | 06:09 PM
chrisp3's Avatar
chrisp3 is infamous around these parts
Finally!....Here's the price for the battery mod....$85 and includes the following components:
1 baseplate (3/8" T60/61 aircraft aluminum)
2 scalloped brakets (1/8" aluminum...1 for each side of the battery)
4 stainless steel 1/4X20 studs
4 lock washers
8 stainless nuts
You will have to drill the four holes for the studs using a 1/4" drill bit (hole placement will be etched onto the aluminum by the laser machine) but the two larger holes (for the bolt that holds the tray to the OEM tray using the factory threaded holes) will be cut on the laser machine. Shipping is NOT included in the cost but will be shipped via FedEx ground service or any of the other Fedex Options....but not UPS.
We MUST order the trays in lots of 10 otherwise the fabricator is not interested in cutting them.
If you are interested please contact me at cp3@pcarmods.com (please put "Battery Mod" in the subject line). As soon as I get firm commitments for 10 pieces I will place the order. Let me know if you have questions.
Old Mar 11, 2006 | 07:03 PM
grussell's Avatar
grussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud of
Pelican parts sells a similar plate for the Optima. I bought one, but ended up doing the lightweight Odessey instead.
https://www.6speedonline.com/forums/...ad.php?t=37240
https://www.6speedonline.com/forums/...ad.php?t=42239
Old Mar 12, 2006 | 03:35 PM
nycebo's Avatar
nycebo is infamous around these parts
Question
How come we have to drill it ourselves? Not that it's that big a deal, but just wondering. That said, do you need to buy a special type of drill bit?
Old Mar 13, 2006 | 08:51 PM
chrisp3's Avatar
To nycebo--the four small holes for the studs that hold the battery down had to be drilled using a drill press becuse the laser machine could not cleanly blow through the 3/8" thick aluminum due to the small radius of the hole. You can use any 1/4" drill bit to drill the aluminum plate.
Cheers!
Old Mar 14, 2006 | 02:08 PM
wyo996's Avatar
wyo996 is infamous around these parts
For some reason I cannot Email you on your post, but I would like one. PM me if you accept Pay Pal. Thanks, Will
Old Mar 14, 2006 | 02:36 PM
chrisp3's Avatar
wyo996...you have mail
Old Mar 14, 2006 | 05:55 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
I see you did not mount the Odessey in the OE spot..........won't fit?
Old Mar 14, 2006 | 05:57 PM
grussell's Avatar
It will fit. I chose the new location to lower the CG and thats where they put the Cup car battery.
Old Mar 14, 2006 | 06:13 PM
GreggT's Avatar
Thanks........(and I apologize for highjacking this thread).......last question on the Odyssey.....that nice clean mount plate came from where?
Old Mar 14, 2006 | 06:15 PM
grussell's Avatar
http://www.odysseybatteries.com/
Old Mar 14, 2006 | 07:02 PM
nycebo's Avatar
So one last question: which one is better to go with for a daily driver? The Optima or the Odyssey?
Old Mar 14, 2006 | 07:06 PM
grussell's Avatar
I like stock or Odessey 925. I don't see a reason to go with an optima. It's only 10 lbs less than stock. The Odessey is 30 lbs less and I can let it sit for a week and it will start right up.
Old Mar 18, 2006 | 09:41 AM
GreggT's Avatar
Suggestions for where battery cable extensions can be sourced?
The odyssey is very small, and if mounted in the OE location with it's 'Hold Down' its "length" puts both of it's terminals either on the right side of the car or the left.
OE cable length appear to allow very little flexibility for that.
TIA
Old Mar 18, 2006 | 05:13 PM
shonuf's Avatar
Member
shonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to behold
coun me in.
carlos
Old Mar 25, 2006 | 03:43 PM
Tonger's Avatar
Tonger is infamous around these parts
Is there any update on whether this will go through?
Thanks,
Tonger
