Strange noise from the Rear
Old Jun 10, 2006 | 01:06 AM
ceddy
Guest
Posts: n/a
My wifes car 2002 C2 suddenly has some strange noise from the engine area. It happens like 3 days ago. When switch to manual gear 1st gear up to 3000 rpm, 2nd gear 3000 rpm and up , it has the jet plane pitch sound like geee, geeeeeeeeeee, the higher the rpm the higher the geeeeeeeee noise. When use automatic gear, the car doesn't go smooth, feels jerking little bid. Would that be from the engine or the transmission? Does anyone seen problem like that? Also we found out that the power steering fluid container is empty, we pull out the cab and check level , It just looks completely dry. Can I just use regular power steering fluid or must get it from dealer.
Now she is afraid driving that cause the noise. How do I check transmission fluid? The manual doesn't show how. Any feedback will be great . Thanks.
Old Jun 13, 2006 | 12:22 AM
nicolaasdb's Avatar
nicolaasdb is infamous around these parts
if it doesn't sound right....bring it to the dealer and let them check it...can never hurt!!
Old Jun 13, 2006 | 01:58 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
I've seen one PSF go dry like yours and so I figured PSF was better than none so agreed the owner on his end. After a full bottle the 996 was back on the road. Yes, we had no other choice but to use a little some from AutoZone since this was found out over the weekend.
-Eli
tzeseong
Aug 17, 2024 11:08 AM
Marcos AMV8
Dec 18, 2015 06:03 AM
dylanX
Cayenne
11
Nov 23, 2015 10:31 AM
docboy
Sep 6, 2015 06:57 AM
Zero911
Aug 24, 2015 06:51 PM
