XM satellite radio
Old Jan 6, 2004 | 10:15 AM
Nova87's Avatar
Nova87 is infamous around these parts
XM satellite radio
Where can I find instructions on how to install a Roady unit from XM? My wife purchased it for me for Christmas and I'd like to do the install myself. The problem is that I have a passport radar detector that utilizes the 12v lighter. So my options are to hardwire the detector or the radio. Also, any suggestions on how to route the wire for the satellite radio?
Thanks.
JD
Old Jan 8, 2004 | 07:17 PM
Nova87's Avatar
Nothing????
Can someone answer a question about the Bose system? Does it have AUX inputs that can be used or are they being utilized by the CD changer?
Thanks,
Old Jan 9, 2004 | 05:49 AM
mziegler38's Avatar
mziegler38 is infamous around these parts
I believe that 2003 cars do not have an aux capability, my CDR23 does not (confirmed with Becker). I did have the Aux installed in my 2002 Boxster though, and did connect an XM as well as my MP3.
You can instal an XM Radio using an FM modulator which works pretty well (using this now for my MP3 in the Pcar). I have the XM set up in my BMW using the modulator.
You can check with Becker at 888-423-3537 ext 1209. Just ask for Burl and give him the model number of your radio.
Old Jan 9, 2004 | 06:39 AM
msindi's Avatar
Mike - can you give us more info/links/pics on how you installed an AUX input in your boxster? I am currently running my ipod using the itrip FM transmitter but the sound quality is not that great and I would reslly love to hardwire it.
Thanx
Nova - I would try and post this and other tech questions on renntech.org...
Old Jan 9, 2004 | 07:16 AM
mziegler38's Avatar
Modulator information link below. There is a plug assembly behind the console used for a cell phone connection. The green/yellow (I believe) is the hot wire which is switched, plenty of ground options there. I added an on/off switch for the modulator power. You can get to the plug assy by removing a small panel just above the gas pedal.
http://www.themindfactory.com/Produc...modulator.html
Old Jan 9, 2004 | 07:22 AM
mziegler38's Avatar
Sorry, I misread your question. Here is the link to the Becker connector.
http://www.beckerautosound.com/porscheconn.html
Old Jan 9, 2004 | 08:36 AM
01 C4 Cab NYC's Avatar
01 C4 Cab NYC is infamous around these parts
Nova87,
Looks like you have an '02 so you should be able to tap into your Becker, call them, you'll need the Aux wiring kit, and then you'll need to tap a power souce.
Call Becker - (201)327-3434 x 1209, (888) 423-3537 x 1209
The kit is part number 1319.116-276
$16.40 plus $8 shipping.
msindi,
If you have an 03, then you have MOST, which is a fiber optic mini LAN in your car. Your SOL, only other fiber optic components can be attached. FM modulator is the only way to go
Old Jan 9, 2004 | 08:38 AM
Nova87,
as a follow up, the AUX is used by the CD Changer, sorry i missed that next post of yours...but call Becker ther may be a way
Old Jan 9, 2004 | 08:41 AM
i think you can change back and forth btwn AUX and CDC electronically...so it should work.
Old Jan 9, 2004 | 09:51 AM
Nova87's Avatar
Thank you all. I will call Becker directly to see how it can be done.
Now if I could only figure out where to put the antenna. A buddy of mine put the antenna on his dash and said he received decent reception so I tried it out on my pathfinder and reception was spotty at best. I have a mini antenna so I don't think it will look that bad on the roof, its just getting that jack and the wire into the engine compartment or under the rear window......
Again, thanks for the help. I'll post what I find out.
vpr80
Mar 6, 2021 12:11 PM
7thsign
Dec 12, 2015 07:43 PM
calexand
Nov 5, 2015 01:05 PM
alpha motoring
Oct 2, 2015 12:04 PM
Mz3bo
Oct 1, 2015 06:32 PM
